Author Topic: It is done.  (Read 41888 times)
Offline sailor723
  • Carma: +416/-1000
Re: It is done.
« Reply #140 on: April 16, 2023, 09:15:48 am »
There was an accident but that is another thread.
Anyways last night after I got home it would refuse to shift into Reverse which was bothersome.
However this morning the errors magically went away and it drives fine. ???
Take it to the Acura Dealer and get the tranny reflashed.  2017 MDXs still had ZF electronic issues.
Brakes not a strong point in that series MDX.
Ir's only money and drink more beer.
https://static.nhtsa.gov/odi/tsbs/2020/MC-10179400-0001.pdf Is it this one?
OK but shouldn't this be a new thread?  Perhaps in "Moan and Whine"?  ;D
Offline marcus_go
  • Carma: +10/-10
Re: It is done.
« Reply #141 on: April 16, 2023, 11:28:36 am »
Ouch the 9 speed. Same issue plaguing the V6 RDX
RDX never got the ZF 9-speed, only the 6-speed, before going to their own 10-speed unit in the current gen.
Re: It is done.
« Reply #142 on: April 16, 2023, 12:10:36 pm »
I stand corrected. I know when I was shopping V6 RDX's for the inlaws that they had transmission issues, just assumed it was the notorious 9 speed)  It's too bad for Acura, just as they  ditched the thirsty blown four and gained the silky six they hobbled it with the janky tranny.
  • Carma: +310/-6812
Re: It is done.
« Reply #143 on: April 16, 2023, 12:15:27 pm »
No idea, but I would be getting the latest reflash.  Mechanically it's a good transmission.  It will probably run you $200.  One simple tranny drain and fill while you are at it.
And another thing.  Those rear diffs have a service interval.  Acura want those drained at the first 20,000 km.  If you have 100K km on it now I'd do that too unless you are dealing it in.
Offline mmret
  • Carma: +240/-570
Re: It is done.
« Reply #144 on: April 16, 2023, 12:34:16 pm »
Ok I’ll talk to the dealer.
Car drives fine this morning.
The diff fluid got changed at some point yeah. Years ago. Never came back up. Maybe worth doing again too.
Not sure what we will do with it but if the trans fluid and reflash go well then might keep.
That makes me feel angry!
Sometimes Borrow: 11 GLK350
  • Carma: +1254/-7210
Re: It is done.
« Reply #145 on: April 16, 2023, 12:37:59 pm »
Good advice here...
Re: It is done.
« Reply #146 on: April 16, 2023, 12:52:43 pm »
First one is 20ish and then every 40k-50kish?
Offline marcus_go
  • Carma: +10/-10
Re: It is done.
« Reply #147 on: April 16, 2023, 12:58:39 pm »
From what I have read, Honda sourced the ZF 9 speed directly from them. Chrysler made them in-house under an agreement with ZF. I think Honda did not have enough capacity for manufacturing their new 10 speed, so they went to ZF to supply them with transmissions. It is why you see some models available with both the ZF 9-speed and Honda's 10-speed.
Lots of issues with the Honda 6-speed, especially on the 2016+ Pilot and Ridgeline. Family friend of ours had their transmission pack it in on their 2018 Ridgeline with only 80k. The ZF should be solid once the updates are done to it and it is maintained to schedule. The fluid changes are expensive though because of the cost of the fluid.
  • Carma: +310/-6812
Re: It is done.
« Reply #148 on: April 16, 2023, 06:23:51 pm »
The first one is indeed 20K.  I stupidly did it and the stuff that was coming out was no different than the fluid coming out.  If Honda wants those diffs changed at 20K km then they should pick up the tab.  Not doing it again.  2022 will be gone @ around 60k km. Subsequent owner can do it.  No rear hitch so WTF.
Offline bridgecity
  • Carma: +126/-182
  • Cars: 2014 MDX; 2007 Tundra
Re: It is done.
« Reply #149 on: April 16, 2023, 08:06:31 pm »
^ Same experience here with our 2014. Fluid looks new when draining out. Seems like such a waste, but I’ve still been following the maintenance minder.
Offline marcus_go
  • Carma: +10/-10
Re: It is done.
« Reply #150 on: April 16, 2023, 08:10:25 pm »
I am wondering if the early change called for in the rear diff is to get out any possible debris from break-in?
Re: It is done.
« Reply #151 on: April 16, 2023, 08:33:37 pm »
Seems to be a Honda thing. On our 2002 CRV the rear axle change intervals were also pretty short, in that case something to do with the limited slip clutch packs.
From what I remember the fluid was very thin, looked like ATF. If you ignored it long enough the axle would chatter going around corners
Re: It is done.
« Reply #152 on: April 16, 2023, 08:48:21 pm »
Same here (fluid looks good)  but I have the change procedure down to an art so it's about 15 mins. If you are draining dark gunk then that would not be a good sign either.
So summary on Honda transmissions. Early Honda 5 speeds (Odessey)  and the 6 speeds were not good. The 9 speed ZF was mostly bad programming, the 10 speed Honda is OK?
Offline mmret
  • Carma: +240/-570
Re: It is done.
« Reply #153 on: April 17, 2023, 09:34:44 am »
Intermittent stuff is awful. Its back this morning.
Offline PoweredSilenceGT
  • Carma: +8/-75
Re: It is done.
« Reply #154 on: April 17, 2023, 09:38:51 am »
What's wrong with the 6 speeds?
Re: It is done.
« Reply #155 on: April 17, 2023, 09:40:07 am »
Shot in the dark but how is the battery and voltage?
Re: It is done.
« Reply #156 on: April 17, 2023, 09:51:26 am »
So summary on Honda transmissions. Early Honda 5 speeds (Odyssey)  and the 6 speeds were not good. The 9 speed ZF was mostly bad programming, the 10 speed Honda is OK?
Honda struggled with judder from the torque converters and clutches wearing out. They released a few TSBs for reprogramming etc but there were still reports of early transmission failure. 2012 forward.
I test drove a 2015? RDX last fall and it was immediately noticeable. The dealer acknowledged it was probably replacement time.
« Last Edit: April 17, 2023, 10:06:56 am by ktm525 »
Re: It is done.
« Reply #157 on: April 17, 2023, 09:52:43 am »
That's is worth checking for sure
https://www.mdxers.org/threads/2017-mdx-transmission-system-problem-blind-spot-info-system-problem-dash-lights-issue-resolved-with-a-new-battery.177635/
The RX gives some oddball warnings when the battery is low, usually about the brakes
Offline valuator
  • Carma: +36/-115
Re: It is done.
« Reply #158 on: April 17, 2023, 10:12:39 am »
My Pilot was doing something similar...I was getting "brake system failure/error" notification (don't remember the exact wording) via the little envelope with an exclamation mark on it, on the infotainment screen.  Then the battery gave up.
Offline mmret
  • Carma: +240/-570
Re: It is done.
« Reply #159 on: April 17, 2023, 10:24:12 am »
That’s worth a shot. Thanks for the idea.
Costco Energizer
or
Motomaster Eliminator?
« Last Edit: April 17, 2023, 10:29:55 am by mmret »
