Author Topic: 2018 Alfa Romeo Stelvio Quadrifoglio  (Read 4008 times)
Offline OliverD
  • Carma: +257/-777
« on: November 16, 2016, 09:16:23 am »
Wow, this looks good.
via Car and Driver
When it comes to naming a vehicle after a roadway, you could do a lot worse than Italy’s Stelvio Pass. More than 9000 feet above sea level at its highest point and consisting of more than 48 hairpin corners on the north side alone, it’s considered one of the best driving roads in the world. So it’s only natural that Alfa Romeo would co-opt the moniker for its new sports . . . uh, SUV? Okay, so it’s not exactly a surprise. And the Alfa Romeo Stelvio just made its in-the-metal debut at the 2016 Los Angeles auto show.
Three for the Road
Assembled at Alfa’s Cassino plant in Frosinone, Italy, the Stelvio is built on the same platform as the Giulia and will be offered in three trim levels: Stelvio, Stelvio Ti, and the high-performance Stelvio Quadrifoglio, which has enough distinct features and tuning to be considered a separate model. While the Stelvio and Stelvio Ti both rely on a 280-hp turbocharged 2.0-liter inline-four for motivation, the high-performance Quadrifoglio utilizes the turbocharged, 505-hp 2.9-liter V-6 from the Alfa Romeo Giulia Quadrifoglio. Aluminum is used extensively in the construction of every Stelvio, including the front and rear subframes, the suspension components (control arms in front, multi-link in the rear), the doors, and the fenders; the rear crossmember is partly made of composite plastics to pare more weight.
As you might have guessed, the base Stelvio and the Ti are positioned parallel to the Giulia. Both pair the turbocharged 2.0-liter with an eight-speed automatic transmission. The 16-valve single-overhead-cam four with direct injection and Fiat’s MultiAir variable-valve-lift system produces the same 280 horsepower and 306 lb-ft of torque as it does in the Giulia. The engine produces full torque at a low 2250 rpm and holds on to it until 4500 rpm. Alfa says the all-wheel-drive system can transfer up to 60 percent of torque to the front axle when needed. It’s linked to the Stelvio’s Chassis Domain Controller (CDC) and driver-adjustable Alfa DNA Drive Mode system, which permits the driver to select among Dynamic, Natural, and Advanced Efficiency modes to modify throttle response, boost pressure, and the settings of the adaptive suspension on the Ti and Quadrifoglio. On the Quadrifoglio, it’s called DNA Pro, while on the base Stelvio, adaptive suspension damping is not available.
A 7.0-inch TFT screen and a pair of traditional white-on-black dial gauges deliver pertinent info to the driver. Leather seating, a Formula 1–inspired flat-bottom steering wheel, push-button start, a backup camera, rear parking sensors, and a power hatch are part of the standard kit. Alfa’s Q4 all-wheel-drive system is standard across the lineup. Harman/Kardon supplies an optional 900-watt, 14-speaker audio system. The standard set of 18-inch aluminum wheels is only one of seven choices, in sizes ranging from 18 to 21 inches in diameter. There are 13 exterior colors offered.
The Ti trim adds standard 19-inch wheels, authentic wood interior trim, and an 8.8-inch infotainment screen in place of the standard 6.5-inch display. Ti buyers will also have the option of selecting Sport and Lusso packages; however, at press time, exact details on these packages were not available.
Four-Leaf Clover
Although the 505-hp 2.9-liter V-6 and its 443 lb-ft of torque may not be all that separates the Stelvio Quadrifoglio from the humbler base and Ti trims, it’s certainly a formidable difference. Alfa’s not pulling any punches here, claiming the Quadrifoglio can knock off the zero-to-60-mph run in 3.9 seconds and is good for a top speed of 177 mph. Helping the cause is an eight-speed automatic transmission, a torque-vectoring rear differential, high-performance suspension tune, more robust brakes, and Quadrifoglio-specific wheels. A 200-mph speedometer, a leather-wrapped steering wheel, carbon-fiber trim, and a set of 12-way adjustable seats carry the racy theme inside. Those interested in taking things even further can specify lightweight carbon-fiber Sparco seats and Brembo carbon-ceramic brakes.
Building on the basics of Alfa’s DNA Drive Mode system, the Quadrifoglio’s DNA Pro setup features a fourth setting, appropriately named Race. When selected, it enables an overboost function for the turbos, opens up the two-mode exhaust, turns off the stability control, delivers sharper brake and steering settings, and dials up more aggressive transmission and throttle calibrations. Basically, it sets the stage for the driver to emerge as either a hero or a zero, based entirely on skill level.
Alfa, which has become notorious after a decade of announcing and then delaying models, takes a huge step toward finally getting its portfolio together with the arrival of the Stelvio. That said, Alfa has not yet revealed any dimensions, pricing, or an on-sale date for the vehicle.
Offline EV-Light
  • Carma: +125/-1490
Re: 2018 Alfa Romeo Stelvio Quadrifoglio
« Reply #1 on: November 16, 2016, 09:57:09 am »
what's up with that horrible hood scoop
  • Carma: +1424/-2124
« Reply #2 on: November 16, 2016, 10:18:39 am »
All that fancy torque vectoring and 8spd automatic and 505 hp tt V6 would sound awesome if it wasn't coming from a car company legendary for their cars exploding mere moments after you signed the purchase papers. Good looking thing, expect to see lots of pics of them on tow trucks and hear lots of owners talk about "soul" and "charachter" as they sit at the dealer repair shop....for the third time that week.
Sent from my SM-G900W8 using Tapatalk
Offline tooscoops
  • Carma: +325/-227
  • "stealership" employee
« Reply #3 on: November 16, 2016, 12:23:42 pm »
meh.. i think we probably give them a bad rap... it would be like some country that only had hyundai back in the day and now only catches glimpses of them from other countries... they'll still be thinking of the old models and all their flaws, when really, they are a much different company and brand.
i think it looks sharp... and the hood scoops are fine to me.
« Reply #4 on: November 16, 2016, 12:26:44 pm »
Uhhh no....Alfa is still about as reliable as an I phone thats been dropped into a full bath tub.....
Offline Sir Osis of Liver
  • Carma: +1376/-1726
  • Ramblin' man
« Reply #5 on: November 16, 2016, 12:44:30 pm »
I'm using this one again:
H. L. Mencken
Offline OliverD
  • Carma: +257/-777
« Reply #6 on: November 16, 2016, 12:49:56 pm »
What are you basing that on?
« Reply #7 on: November 16, 2016, 01:19:12 pm »
http://www.autoexpress.co.uk/car-news/consumer-news/91220/the-most-and-least-reliable-car-manufacturers-2016
Offline OliverD
  • Carma: +257/-777
« Reply #8 on: November 16, 2016, 01:41:49 pm »
Better than Jeep and I don't see you bitching about yours. :P
« Reply #9 on: November 16, 2016, 01:43:32 pm »
The Wrangler just works....I think its all the rebadged Fiatsler crap that they have issues with. My wifes friends GC with the 3.6 has had all sorts of issues, guy at work bought a Patriot, all sorts of niggly issues, the JK, touch wood, just worked.
Offline Calbrez
  • Carma: +2/-10
« Reply #10 on: November 18, 2016, 06:26:26 am »
Funny that's how I feel about VW.  Owned 2 of them and they were both garbage in terns of reliability... terrible electrical issues (lights would go completely out on the highway at night, dash emitted smoke when electrical wiring burned), window problems, leaky sunroof... muffler toast after 3 years...  Don't know how they do it  but that carmaker continue to fool the world.. maybe it's this bizarre idea that everything German s well made...
This Alfa looks great.  People need to step outside of the Toyota/VW/Honda?Hyundai box and try something new.
  • Carma: +471/-416
« Reply #11 on: November 18, 2016, 07:39:00 am »
Quadrofoglioing makes you BLIND..................... 8) 8) 8) :P
