Viktor,
Could you tell us more about the additives?
Hi rrocket,
In short, ATOMIUM is a tribotechnical compound containing neutral auto-chemistry formula. ATOMIUM technology uses the unique properties of natural minerals aimed to rebuild worn friction units of engines, gearboxes, fuel pressure pumps, hydraulic power steering and other units of the vehicles and industrial facilities. ATOMIUM technology optimizes the contact of friction pairs in engine parts that leads to improved technical parameters that can reach the nominal.
In the friction zones a new car engine has a new layer formed, and despite the fact that the gaps are nominal ATOMIUM ™ anti-friction properties will provide decrease of the friction losses, i.e. increase the mechanical efficiency. This reduces fuel consumption, increases power and engine response. But the most important both for old and new engines is an increase of their lifecycle provided by ATOMIUM ™ properties, that can postpone a major repair up to 50 - 150 thousand km of the run. Moreover in cases of gentle car operation with the help of ATOMIUM you can cancel the overhaul at all.
I also have a short video explanation of Atomium.
