Author Topic: What did you do to your car today?  (Read 3011640 times)
  • Carma: +310/-6812
« Reply #8600 on: April 28, 2018, 09:36:27 pm »
I enjoy the top down a lot more in the evening/night-time
^^ or overcast days.  I don't drive top down in the sun.
  • Carma: +1254/-7212
« Reply #8601 on: April 29, 2018, 12:15:31 am »
Scored a set of Weathertech's for the Escalade for a steal. Should come in handy with the kid...
Get a can of this and spray it on. Mind will be blown. Also...spray on all the door seals on your car and you car will get quieter.
Amazing stuff and one of the best OTC car care products I've ever bought.
http://www.canadiantire.ca/en/pdp/kleen-flo-rubber-care-0381573p.html
« Last Edit: April 29, 2018, 12:17:54 am by rrocket »
« Reply #8602 on: April 29, 2018, 12:34:47 am »
^^ What’s it going to do for the Weathertechs? Mine are 8 years old and I’ve noticed no deterioration.
If it just makes them shiny and slippery, no thanks.  :P
Offline UnknownJinX
  • Carma: +22/-115
« Reply #8603 on: April 29, 2018, 01:43:46 am »
Did a lot of work on Thursday.
The rear fog light required me to remove a good chunk of stuff. Safe to say that I am done with wiring work for a while. Just need to put in a modified switch and it should be all done.
The drive belts aren't hard to replace. I did notice that the old belts are very dry compared to the new ones.
The new AutoExe steering wheel is awesome, and a lot nicer to hold. The only thing that's a bit annoying is that it's a bit crooked. Booked for an alignment on Tuesday.
« Last Edit: April 29, 2018, 01:45:53 am by UnknownJinX »
« Reply #8604 on: April 29, 2018, 09:02:02 am »
Will give it a shot....not sure if I'll do the mats with it, but it sounds like a good alternative to silicone lube for seals, which I don't like.
Offline jamie1
  • Carma: +22/-20
« Reply #8605 on: April 29, 2018, 11:06:01 am »
Looks to be similar to the Wurth rubber care. I'll have to check it out. We don't have Wurth products at my shop anymore and I loved that stuff.
« Reply #8606 on: April 29, 2018, 11:13:56 am »
It's great stuff...and actually is killer on mats too!
https://youtu.be/NdJ-D5iKdg4
« Reply #8607 on: April 29, 2018, 11:15:31 am »
I like it as much as other stuff I've used (Gummi Flege, Honda Shin-Etsu)...but much easier to apply.
Other bonus is easy to find and not obscenely priced.
Offline Arthur Dent
  • Carma: +186/-80
  • 42?
« Reply #8608 on: April 29, 2018, 01:19:18 pm »
New water pump in. Radiator back in. Need a new top hose as well as some new heater hoses.
  • Carma: +268/-457
« Reply #8609 on: April 29, 2018, 03:26:10 pm »
I installed the airbags and trailer brake controller.  Oh, and did my tire swap at the same time.
p
Offline marcus_go
  • Carma: +10/-10
« Reply #8610 on: April 29, 2018, 04:21:45 pm »
And got the Porsche outta the barn. Started up right away, ran great all the way home, no issues. This week I'll change out the oil & give it a quick once over. Last fall it sounded like the front right wheel bearing was getting loud, didn't notice much today.
I surprised that there is anything left of your Porsche  :o
After driving on the roads in Ottawa today  :shake:
It only has 16" wheels with a decent sidewall, so it's not too bad. And razor sharp steering for quick maneuvers, lol!
Some of those potholes would  swallow  up your car  ;D
Beautiful. 944 Turbos are so rare now. I wish my dad never sold his.
« Reply #8611 on: April 29, 2018, 05:16:17 pm »
GBA, great work on the air bag kit. I am curious to know how it works for you.
  • Carma: +310/-6812
« Reply #8612 on: April 29, 2018, 05:21:37 pm »
Nice job.  So the "kit" contains the bags and new springs and of course the hose.
So what kind of spring compressor did you use.  Crappy ones like mine.  :P
« Reply #8613 on: April 29, 2018, 05:22:36 pm »
Got the '72 MGB up and running again. Started first crank; threw on a nice little chrome exhaust tip I had kicking around, drove it around the block and then replaced the front brake flex lines.....I'd say they were due:
Also discovered that the brake lights had quit, but was quickly able to trace it to a broken wire off the pedal switch, little solder and things were good again.
« Reply #8614 on: April 29, 2018, 05:26:11 pm »
He probably didn't use one at all. Pull the lower shock bolts and lower the axle down enough (body of the van supported on the jack stands) with the floor jack until you've got enough room to pull the spring out; reverse applies for putting them back in. The beauty of simple solid rear axles.
  • Carma: +268/-457
« Reply #8615 on: April 29, 2018, 06:17:04 pm »
Correct.  Just disconnect the shock absorber, then pull the axle down enough to pull the spring out.  Also, unused the existing spring.  The kit contained only the bags, hose and fittings.
Wiring in the brake controller was a pain in the ass.  Grand Caravans aren't pre-wired, so I had to feed wires through the firewall to get power, ground and brake signal.
Offline Solstice2006
  • Carma: +245/-468
« Reply #8616 on: April 29, 2018, 08:53:42 pm »
Sssh, don't tell tooscoops, I did this to my leased GC!
Offline BWII
  • Carma: +188/-376
« Reply #8617 on: April 29, 2018, 11:34:45 pm »
Swapped out the SS badge
Sneaky!  Now it's a V6 too, right?  ;D
Did I say something the other day about why pay someone to change your oil?  I must've been drunk.  I changed oil on the truck today.  YTF do I constantly put myself through that shi# with that POS...mofo what a pain in the ass.  Getting the stupid plastic plate off the bottom is fun, dust in your eyes, just awkward...of course stripping the one "nut" by over-tightening it when putting it back on...banged my finger into the frame trying to loosen the drain plug, after I used the wrong size socket and almost turned the damn thing round...WTF?  How'd I eff that up? Grrr...bruised nail now and I was bleeding like a stuck pig (no idea where that comes from...do stuck pigs bleed?  ??? I probably have that wrong today too...).  Getting the filter off is another test of one's patience.  I need a filter relocation kit...effing Ford...grrr... >:(
Changing the air filter also a PITA.  Why can't they make those filter cases easier to open?  Had to use a screw driver to pop it...guess I can say I got that right because I didn't hit the paint.  :P
I don't mind changing oil...but they could've maybe asked some German's how to make it easy...  ::)
Offline tenpenny
  • Carma: +137/-305
« Reply #8618 on: April 30, 2018, 11:07:59 am »
"bleeding like a stuck pig (no idea where that comes from...do stuck pigs bleed? "
That expression comes from the slaughterhouse, where you dip the pig in boiling water to get the hair off, then hang it by the feet, then stick it with a knife to kill it/drain the blood.
Offline OliverD
  • Carma: +255/-771
« Reply #8619 on: April 30, 2018, 11:50:18 am »
So the pig gets boiled alive?
