Author Topic: What did you do to your car today?  (Read 3014138 times)
Offline Bubba
  • Carma: +382/-442
    • My photo site
« Reply #7200 on: June 24, 2017, 04:10:19 pm »
Got my Thing back from the shop yesterday.  The mechanic sorted everything out and she runs great.
She's slow and noisy, with a buckboard ride, and I love it.   ;D
  • Carma: +1424/-2121
« Reply #7201 on: June 24, 2017, 05:05:28 pm »
Finally got Bilsteins for the JK....was going to install them today but the lady of the manor had other plans
« Reply #7202 on: June 25, 2017, 04:05:40 pm »
Congrats 84im!
Got some work done on the Orange MGB this weekend. Installed a new alternator, which solved my charging woes. Then it started running like crap and dumping gas out of the evap system, a telltale sign of a stuck carburator float; unlike the early design SUs, these later ones have bowls at the bottom of the carb, so I had to remove both carbs completely to take the bowls apart and un-stick them. Fortunately, that did the trick and the car is running well again. Repaired an interior door panel and then started buffing the paint, got the trunk lid and area around it done before I ran outta time, good news is that the paint is coming up really nice without too much effort.
Offline 84im
  • Carma: +24/-81
  • Cars: 2015 BMW X1, 2003 Chevy Tracker, 1974 VW Dune Buggy, and 1974 VW Thing
« Reply #7203 on: June 25, 2017, 05:12:37 pm »
Yesterday I installed new calipers on my wife's Chevy Tracker.  The rotors were still in good shape and the pads were only half worn, so they were both reused.
After installing the calipers and bleeding the entire system a couple of times I took it out for a test drive.  The brakes work great except the pedal goes down 2/3 of the way to the floor.
The brakes aren't spongy and pumping the brakes doesn't bring the pedal back up.
Weird.
A computer once beat me at chess, but it was no match for me at kickboxing.
« Reply #7204 on: June 25, 2017, 05:17:59 pm »
Discovered someone keyed the Corolla.   >:(
Looks like it's only in the clear, so I'm going to try to polish it out.
« Reply #7205 on: June 25, 2017, 05:25:00 pm »
Weird.
I assume you replaced or at least cleaned and lubed the slider pins extremely well? I had the same issue with the Firebird and new pins did the trick...I did the rotors/pads at the same time, but in theory that shouldn't be your issue.
The other thing to check is the flex lines, especially the fronts. Have someone step on the pedal and watch the front lines, if you see them bulge, swell or anything like that change them. If their is 'give' in the rubber lines it'll noticeably increase pedal travel.
Offline Arthur Dent
  • Carma: +186/-80
  • 42?
« Reply #7206 on: June 25, 2017, 05:51:46 pm »
Got the transmission swap finished up on the MG B. Wouldn't you know it the darn thing won't start now. Get fuel, spark, and timing/spark plugs ok but won't run. Ugh. ???
« Reply #7207 on: June 25, 2017, 06:56:57 pm »
That's an odd one...If you know you're getting fuel to the carb(s?) and spark it'll almost always run....Maybe terribly, but it'll run. This is the same engine that was in the car prior, right? Does it sputter or try to run, or just crank and crank forever?
Only thing I could think of that would cause it to not run at all given spark, fuel, air and compression is if the timing is exactly 180deg off...usually the result of someone putting the rotor on inside the distributor cap backwards - check that if you opened the distributor at all since it last ran. Ignition wires on the right plugs? What about the wires to and from the terminals on the coil - are they connected correctly?
« Reply #7208 on: June 25, 2017, 06:59:39 pm »
^^^  Yeah, if there's spark and fuel and the some compression, it should at least run in some fashion.  I concur that it's probably some sort of timing issue.
Is the check engine light on?    :rofl2:
  • Carma: +310/-6812
« Reply #7209 on: June 25, 2017, 09:06:23 pm »
Weird.
How did you bleed the system?
Offline Arthur Dent
  • Carma: +186/-80
  • 42?
« Reply #7210 on: June 25, 2017, 09:15:12 pm »
I think .... it might be something electrical. It catches then dies as soon as I am off the starter. I thinking it is loosing power to the coil when not cranking.
« Reply #7211 on: June 25, 2017, 10:07:10 pm »
There's a wire that runs from the harness on the passenger's side of the engine bay, across the area where the oil filter is and into the side of the distributor...I *think* it's beige/brown striped. It's in a stupid location and always gets beaten up, it's a main power feed into the distributor from the ignition, check that it's connected up properly and then check the wire itself for continuity. I've had trouble with that wire before (accidentally pulled it when removing an oil filter and spent hours chasing a no-start).
Offline Arthur Dent
  • Carma: +186/-80
  • 42?
« Reply #7212 on: June 25, 2017, 10:15:42 pm »
Thanks. I'll hunt for it. Oh the same engine, etc. Just the transmission was swapped.
« Reply #7213 on: June 26, 2017, 01:10:34 am »
Just ordered a leveling kit for the Jeep.....can't wait for the new springs to arrive.
Sent from my SM-T377W using Tapatalk
  • Carma: +308/-518
« Reply #7214 on: June 26, 2017, 07:44:17 am »
Just bringing the front end up? Or a small lift in the rear as well?
« Reply #7215 on: June 26, 2017, 08:37:29 am »
2' in front and 1" in the back
  • Carma: +308/-518
« Reply #7216 on: June 26, 2017, 08:41:17 am »
Nice, should be able to run 33's with no issue after that  :stick:  ;D
Offline 84im
  • Carma: +24/-81
« Reply #7217 on: June 26, 2017, 09:02:02 am »
Weird.
I had my wife sit in the driver's seat and apply the brakes.
Offline Bubba
  • Carma: +382/-442
    • My photo site
« Reply #7218 on: June 26, 2017, 11:12:22 am »
Two feet in front?
« Reply #7219 on: June 26, 2017, 11:17:33 am »
That would involve a regear...and if I was going to regear, no way would I keep the stock axles......and if I was going to put some 1 ton axles on it why would I bother with only small little 33's, might as well stuff some 40's under there  ;D
