Saturday morning I started the day by replacing the EVAP Purge Solenoid in the Escalade....Damn Evap codes. Then I pulled the Sonoma & SLK outta the garage for the first time this year, ran them both around the neighbour hood & cleaned up in the garage. Then I went to my grandma's place and did some work on the MGB....re-wired the fuel pump and attempted to replace the alternator (the one on it is fried). Turns out the spare alternator I had is actually an older design and it would require too much re-wiring to make it work, so I am gunna have to source a replacement this week and get it back together....Came home to do yard work and open the hot tub.
Sunday was crappy weather, so the only car related thing I did was take the MGB air cleaner assembly apart and repainted it.
Monday was an oil change for the SLK, and while I was at it I washed all the under tray panels and waxed the underside of the hood. Then I washed the SS and called it a day.
