Author Topic: What did you do to your car today?  (Read 3013533 times)
Online Gurgie
  • Carma: +308/-518
« Reply #6500 on: January 10, 2017, 11:07:52 am »
Not me, but my mechanic.
Rear suspension & front pieces as well by the looks of it? What are you replacing?
Also, tell him to take it easy on those Henekin's if he's going under your car  :rofl:
Online Firm
« Reply #6501 on: January 10, 2017, 11:19:39 am »
I have a couple of NOCO battery tenders too.
Interestingly enough, mine won't charge a dead battery.  I left the door ajar on our Chevy Tracker for 3 days, which killed our fairly new Crappy Tire battery.  I hooked up my battery tender and left it on for 24 hours, thinking it would bring the battery back to where I could start the car.
Didn't happen.
I ended up using my little emergency battery pack booster.  The Tracker fired right up and I took the car for a long drive on the highway to charge the battery.
When I got back home I hooked the battery tender back up (battery showed 25%) and the next day the battery was back to fully charged.
That's "no spark" tech. A lot of the new "smart" chargers, like BT and Noco will not put power to the clamps until they detect that a battery is correctly hooked up. This is a safety feature to prevent the clamps from sparking and causing fires or explosions (hydrogen gas from batteries is explosive!)
Each brand/model of charger has a different minimum voltage threshold - in this case your tracker battery was discharged below the minimum voltage (usually around 0.5-1V) so the charger didn't detect it, and therefore wouldn't charge. What you did is the correct solution; attach another battery (or booster) to boost the voltage a bit, then hook up the charger.
Solstice; it sound like your situation is a bit different. The charger was on and charging, but a camper battery is typically pretty big, and a NOCO G1100 is only 1.1A (or close). It would take days, maybe close to a week for a charger that small to fully charge a depleted camper battery back up to full.
For example; when I brought the Camaro SS home, the battery in it was totally flat, I hooked it up to my Ctek 3300 (3.3A) and it took about 2 days for it to come back to a full charge.
Something with an output as low as the G1100 is best on powersport batteries (smaller), or as a maintainer on larger batteries (cars, campers, boats, etc).
Offline Solstice2006
  • Carma: +245/-468
« Reply #6502 on: January 10, 2017, 11:44:10 am »
Didn't happen.
I will keep that in mind.  IIRC, it's one of the Motomaster Nautilus series.
Offline aquadorhj
  • Carma: +271/-265
« Reply #6503 on: January 10, 2017, 12:11:48 pm »
Rear subframe/subframe mount, diff mount, diff cover, caliper carrier brackets and rear control arms?
why the overhaul on the rear on your m3?
Offline normancw
  • Carma: +125/-132
« Reply #6504 on: January 11, 2017, 12:32:11 am »
The project started off with reinforcing the rear subframe, a known weakness of E46 coupes.
Then we decided to go further while we were there (solid diff and subframe bushings, suspension refresh with new lower control arms, upgrade up from KW V3 to AST 5300 3-way adjustable coilovers, CSL brake calipers and larger discs, brake ducts, weight reduction...).
― rrocket
  • Carma: +1254/-7213
« Reply #6505 on: January 11, 2017, 12:47:27 am »
An issue on the Z4 too isn't it?
Offline normancw
  • Carma: +125/-132
« Reply #6506 on: January 11, 2017, 01:38:34 am »
Yep.
Offline Triple Bob
  • Carma: +308/-574
  • Profesional Dash Stroker
« Reply #6507 on: January 11, 2017, 12:52:46 pm »
Awesome, good job!
« Reply #6508 on: January 11, 2017, 06:28:56 pm »
Changed the front brakes on the LS today.  Honestly, the easiest brake pad change ever.  It's ridiculous.  Pull one pin, pull pads, put in new pads, replace pin.  It was stupid how easy it was.  I was able to compress all 4 pistons in the calipers while leaving it on with my amazing ratchet brake pad spreader.  And the pads I used required no anti-squeal (not sure about this part).
I'd be surprised if it took 10 minutes per side total.
If only all cars were so easy.
Also, the LS430 calipers are massive and would make a great "big brake" upgrade kit for many cars.
« Last Edit: January 11, 2017, 06:35:23 pm by rrocket »
Offline normancw
  • Carma: +125/-132
« Reply #6509 on: January 11, 2017, 07:32:41 pm »
Those calipers look new!  How old is your car again?
« Reply #6510 on: January 11, 2017, 07:42:17 pm »
^2004
I though so too.  Must be a coating on them.  Not a spec of rust on any caliper.
FWIW, brake/caliper specs: 315mm and caliper are 4x42mm piston.  To compare, my Supra were 323mm and 4x38mm.
« Last Edit: January 11, 2017, 07:46:47 pm by rrocket »
Online Gurgie
  • Carma: +308/-518
« Reply #6511 on: January 12, 2017, 08:50:47 am »
Put the Thule on last night, ready to take the family skiing this weekend now ;D
Sent from my SM-G850W using Tapatalk
« Reply #6512 on: January 12, 2017, 09:23:15 am »
WOW, the 4 wheel ability is great , you can drive  on walls like the batmoblie   :o  :rofl2:
Online Gurgie
  • Carma: +308/-518
« Reply #6513 on: January 12, 2017, 09:27:53 am »
Super sticky Toyo's!  :rofl:  :rofl:
Damn cell phone pics when they load up using Taptalk, they're correctly orientated on my phone  :banghead:
« Reply #6514 on: January 12, 2017, 09:34:00 am »
It is crazy the way they get posted sometimes
Offline KD
  • Carma: +359/-263
« Reply #6515 on: January 12, 2017, 11:16:04 am »
How many kegs can you fit in that thing?  ;D
Online Firm
« Reply #6516 on: January 21, 2017, 05:51:29 pm »
Took advantage of the warm (yet damp and foggy) weather to give the Escalade a good mid-season clean up. Washed it, hosed the underside, scrubbed the mats, waxed the rims (I hate running chrome in the winter), washed the cupholders, etc.
  • Carma: +245/-468
« Reply #6517 on: January 21, 2017, 09:04:25 pm »
Every time the weather warms up and I want to do that, the car is gone for a couple of days.  I tidy up the van once a week on the inside.  But the car gets neglected, as she takes it to work.
Online Firm
« Reply #6518 on: January 22, 2017, 07:01:36 pm »
^Yep, that makes it tough.
It's that time of year where I start itching to get back into the car stuff....but I know the mild weather will be short lived, so I won't dig into any projects. I did pump the tire pressures in the SS up to 40psi all around; I forgot to check them when I 'stored' the car, and when I checked them today they were all at 25psi.
Oh, I also fixed a 12V outlet in the Escalade, the contact point at the bottom was dirty/crusty so sometimes you'd plug in your device and it would take some wiggling before it made good contact. Pulled the socket out, cleaned it up with some steel wool and put it back together, works perfect now.
Offline aquadorhj
  • Carma: +271/-265
« Reply #6519 on: January 26, 2017, 06:35:33 pm »
Drove my bimmer first time in a month.  5 degrees, road is relatively clean, perfect condition.
Stupid car was understeering everytime i took a corner hard... Too much dust.
