Author Topic: What did you do to your car today?  (Read 3014083 times)
« Reply #6320 on: November 24, 2016, 12:10:58 pm »
As for me....
I got the Escalade headlight fixed; 3 ballasts and $500 later!  >:( I also washed it.
Headlight went back out yesterday. Unbelievable. Oh how I miss the old days of simple Halogens and a two wire plug :(
I have zero ambition, time or patience to take the thing apart for a 4th time, so I dropped it off at a friend's shop this morning. My guess is that there's some voltage spikes or drops on that circuit that keeps killing the ballasts....Time to let someone else figure it out.
  • Carma: +1424/-2121
« Reply #6321 on: November 24, 2016, 12:26:33 pm »
As for me....
Been there......when you are so mad you are standing beside the car with a 5 gallon jerry can of gas and a lighter.....
« Reply #6322 on: November 24, 2016, 01:10:05 pm »
As for me....
Yep.
Shop just called. Apparently they checked the complete circuit and everything is fine, another new ballast going in now. My guess is that I'll get another week or so out of it before I gotta bring it back to the shop - at least then the next ballast(s) will be on their dime.
Offline Noto
  • Carma: +774/-2132
« Reply #6323 on: November 25, 2016, 09:26:03 am »
I bought this guy:
https://m.canadiantire.ca/#/products/productDetail/0111912P/false/false/false?productCode=0111912P&isNonOnline=false&isAutomotive=false&isBarcodeValue=false&selectedProductCode=0111912P&selectedSku=0111912&quantity=1
... For my dad. He didn't have an air compressor, and he needed a battery to run an air pump in the summers... Si it seemed good.
I still am staying the course for my own needs.
  • Carma: +244/-779
« Reply #6324 on: November 25, 2016, 09:57:18 am »
I bought this guy:
That's pretty decent, a booster/compressor for the price of only a booster.  Just keep it topped up or the battery goes in a couple of years.
I have a booster pack that wasn't holding charge any longer, I took it apart and found it had a battery exactly the same size as my jet-ski batteries so replaced it with one of those.
« Reply #6325 on: November 25, 2016, 10:09:34 am »
I bought this guy:
That's one of the products I used to manage  ;D
It's a quality unit, but as Blur suggested, make sure you charge the battery every couple of months to keep it topped up, otherwise it'll be a doorstop in a year....
I have one at home that's probably 4-5 years old now. It still works great for boosting, but the compressor stopped working about a year ago. It runs, just doesn't pump any air, I assume a seal gave out inside. Doesn't seem to be a common issue though.
Offline Bubba
  • Carma: +382/-442
    • My photo site
« Reply #6326 on: November 25, 2016, 06:25:35 pm »
I bought this guy:
I have the 500 amp Stanley and set a monthly reminder to charge on my computer.
  • Carma: +244/-779
« Reply #6327 on: November 25, 2016, 08:25:56 pm »
Trying to fix a couple of issues with the Outback, when I reassembled it last I got the steering shaft off by one spline which not only made the steering wheel slightly crooked, it faulted out the anti-skid stability control.  Also, it had a O2 sensor heater fault code which for some reason faulted out and disabled the VDC (Vehicle Dynamics Control) part as well.
So, put it up on jackstands, take out the bolt holding the steering shaft drop the steering rack down, disconnect, realign over one spline, reconnect and tighten everything up.  Sounds simple, takes hours of farting about contorted under a car.  Think it's good now, have to drive to be sure.
For the O2 sensor heater I went to the wiring connector which was already screwy from a "recycler" cutting the wiring instead of disconnecting the plug.   I pulled it apart to check the heater and when I put it back together it pushed out the two pins that were almost broken, so now it's totally screwed.    Instead of screwing around with finding a new connector I cut the wires, soldered in an extension wire and bypassed the connector.  Still throws the P0051 heater code.  Check some voltages, it's getting power, but I'm also getting 12vdc on the return wire.  I find out which ECU to engine connector it goes to, disconnect and reconnect it, code goes away, check engine light out.  Wish I'd done that in the first place.
Offline mlin32
  • Carma: +65/-419
« Reply #6328 on: November 27, 2016, 12:56:23 pm »
Replaced engine air filter and cabin microfilter on the Tiguan.
« Reply #6329 on: November 27, 2016, 04:53:58 pm »
My weekly check of washer fluid and my every-1000-kms check of oil level  and tire pressure.
Offline KD
  • Carma: +359/-263
« Reply #6330 on: November 27, 2016, 05:11:49 pm »
Re-torqued the wheels and checked tire pressure on the truck and wife's car.
Offline OliverD
  • Carma: +255/-771
« Reply #6331 on: November 27, 2016, 05:28:37 pm »
Weekly?  :o
Offline mlin32
  • Carma: +65/-419
« Reply #6332 on: November 27, 2016, 07:22:55 pm »
Lol washer fluid.......there's a warning light for that  ;D
During the winter, I carry a small bottle (100ml?) of concentrate in the cargo area. Headlamp washers can consume it quickly.
Offline Weels
  • Carma: +253/-259
  • This is my happy face
« Reply #6333 on: November 27, 2016, 08:24:33 pm »
 :(  See ya sometime...
Offline Bubba
  • Carma: +382/-442
    • My photo site
« Reply #6334 on: November 27, 2016, 08:30:31 pm »
Offline Scaerio
  • Carma: +193/-127
« Reply #6335 on: November 27, 2016, 09:50:30 pm »
Threw out all the parking receipts that had accumulated in the cup holders...
« Reply #6336 on: November 27, 2016, 11:23:53 pm »
Escalade is still in the shop waiting on new parts to get the headlights sorted out.....what a joke.
So the red Firebird has been running primary duty. Put 400kms on it since Thursday night, so I gave it a bath, cleaned all the glass, and checked all the fluids today.
« Reply #6337 on: November 28, 2016, 06:02:10 am »
Weekly?  :o
headlight washers.  Every 1000 kms is about once a month
« Last Edit: November 28, 2016, 06:04:06 am by tpl »
Offline Noto
  • Carma: +774/-2132
« Reply #6338 on: November 28, 2016, 08:27:52 am »
Consider pads for under the tires?
Offline carcrazed
  • Carma: +39/-88
« Reply #6339 on: November 28, 2016, 08:57:15 am »
Finally got my first-ever winter shoes for the MDX. I'm still getting used to the softness.
That TPMS warning is a bit annoying, but I'll get used to it for the next five months.  :P
