Author Topic: What did you do to your car today?  (Read 3015434 times)
Offline mmret
  • Carma: +240/-570
« Reply #5340 on: March 27, 2016, 06:08:34 pm »
.. your BMW uses lugs? Every FGC I've had used bolts.
That makes me feel angry!
Sometimes Borrow: 11 GLK350
Offline 2JDM
  • Carma: +119/-141
« Reply #5341 on: March 27, 2016, 06:13:32 pm »
Yes, it uses bolts. My mistake.
Offline mmret
  • Carma: +240/-570
« Reply #5342 on: March 27, 2016, 06:50:46 pm »
Do you have mounting pegs?
  • Carma: +1254/-7213
« Reply #5343 on: March 27, 2016, 07:09:14 pm »
Spent 3+ hours getting the LS to factory ride height specifications. It's a tricky process. What you do in the front affects ride height in the back..And vice versa. And also kitty corner!  Lots of trial and error.
But now the car doesn't look as nice IMO. The rear rides about 10mm lower than the front from the factory. And that translates to a fender-to-do road difference of just under 1" compared to the front.
Offline KD
  • Carma: +359/-263
« Reply #5344 on: March 27, 2016, 07:24:18 pm »
Tried to do the winter tire swap today but couldn't! I couldn't get the first wheel off.
Things I tried: kicked it, smacked the inner side with a 2x4 and lowered the car while the lug nuts were off. I wasn't ballsy enough to drive around the block with the lug nuts off...  :P
Argh. I have to go to my mechanic tomorrow to get 'em swapped. $20. I was gonna paint my calipers black too.  :'( >:(
Aluminum rims?  If so, i wonder if they are more of a pain to get off than steel?  I've been using steel rims in the winter for so long that I can't remember last time i changed an aluminum rim in the spring.  I spread a little grease on the rims before i put them on and never have a problem getting them off.
I have to paint the calipers on the S2000 as well, but not until the weather gets a lot warmer.  They look really bad considering the rest of the car still looks like new.
Offline pi314
  • Carma: +59/-95
« Reply #5345 on: March 27, 2016, 07:34:43 pm »
The Focus wheels are impossible to get off, even with steel rims. I'm going to let Costco do the swap, then soon after take the wheels off at home and put some of that anti-seize stuff stuff on it.
« Reply #5346 on: March 27, 2016, 08:31:12 pm »
Anti seize brake paste IIRC. It has metal (alum or copper) dust in it. Should work around the hub just fine. I'd use aluminum based paste in case of alloy wheels.
Offline 2JDM
  • Carma: +119/-141
« Reply #5347 on: March 27, 2016, 09:11:32 pm »
Not sure what those are...All I know is its a PITA to line up the holes for the bolts to go in.  :P
Yes, they are alloy rims. My calipers are rusty as well.  :(
I was gonna put anti-seize paste but obviously the seizing got there first.  :P
Offline mmret
  • Carma: +240/-570
« Reply #5348 on: March 27, 2016, 09:17:11 pm »
http://www.reverselogic.us/lug-bolt-guides.html
These are quite helpful as often the "lip" on the hub is very small.
If you have non hubcentric wheels it would be quite some annoying process to do it without these pegs.
« Reply #5349 on: March 27, 2016, 09:31:22 pm »
^ Check you spare tire tool kit...MY SLK has one of those peg things in the factory kit. I've never used it, but it seams helpful.
Offline mmret
  • Carma: +240/-570
« Reply #5350 on: March 27, 2016, 09:58:37 pm »
Good point. The GLK came with 2.
The BMW we had didn't come with any but it was bought used.
« Reply #5351 on: March 27, 2016, 10:06:02 pm »
Let me know if you need a peg. I'll make one at work for you.
« Reply #5352 on: March 29, 2016, 07:07:04 pm »
Dropped the LS off to have the bumper fixed from the monster racoon I hit.
Am NOT impressed to have a 2008 Honda Civic as my rental (was promised their ES350 loaner).
I will be going back tomorrow and getting a rental from Enterprise.  Even if it's a cheap, new car (Nissan Note?) I'll be fine...I won't be letting the repair place get any more rental money for breaking their promise.
« Last Edit: March 29, 2016, 07:09:43 pm by rrocket »
Offline Solstice2006
  • Carma: +245/-468
« Reply #5353 on: March 29, 2016, 07:15:01 pm »
your paying to rent an 08 civic from the repair shop?
Offline mlin32
  • Carma: +65/-419
« Reply #5354 on: March 29, 2016, 07:16:43 pm »
Is this a dealership?
I've only once had a non-dealership repair place give me a rental/loaner.......it was a E32 735i which was surprisingly high-tech considering its age- almost as old as I am ! I liked it quite a bit.
« Reply #5355 on: March 29, 2016, 07:19:23 pm »
Yea!  They have a fleet of loaners.  Last time I got their 2015/16 Corolla when I brought the 911 in.  This time I asked (and was promised) their ES350.  However, when I came in, the ES350 was still out on loan.  So my choices was the Civic and a couple Mazda3.  This was right before work, so I was more or less screwed...so I took the Civic.
Like I said...tomorrow I`ll have something from Enterprise instead.
« Reply #5356 on: March 29, 2016, 07:21:59 pm »
No, it`s the best body place in town.  They have their own rental fleet.
http://www.formulafirstcollision.com/
Offline mlin32
  • Carma: +65/-419
« Reply #5357 on: March 29, 2016, 07:25:46 pm »
^ Oh that's a nice shop........with a bistro !
« Reply #5358 on: March 29, 2016, 07:28:11 pm »
Food is great too!!  And they have a park out back with a gazebo where you can eat.
There are factory certified for Audi, BMW, Lexus, Porsche, Mini and ProFirst Honda certified.
They are also one of the few Lexus LFA certified places and are certified for aluminum body repairs from most manufacturers.
Offline KD
  • Carma: +359/-263
« Reply #5359 on: March 29, 2016, 07:35:07 pm »
And they gave you a 2008 civic?   :rofl: :rofl2:
