Author Topic: What did you do to your car today?  (Read 3015458 times)
  • Carma: +1254/-7213
« Reply #5280 on: March 15, 2016, 09:19:02 pm »
Jacked up each corner of the GTI to check for bad wheel bearings.
Just starting yesterday, I've been hearing a loud rumbling/whining noise at highway speeds. Sounds like tire tread whine, but seemed odd that it would start suddenly like that (tires have been on all winter.)
Anyway, all four wheels spin quietly and freely, with no play, so sure seems like all the wheel bearings are good. Maybe it really is just tire noise? Guess I'll find out when the summers go back on (hopefully in a few weeks.)
Switch the offending tire to the opposite corner...that will tell you ASAP
« Reply #5281 on: March 15, 2016, 09:30:42 pm »
^^ Yeah, might try that. Not 100% sure where the noise is coming from, though. Seems like right rear, but even with the windows rolled down, it's not obviously coming from one spot. Maybe I'll start with switching the rears side-to-side and see if anything changes.
Offline Triple Bob
  • Carma: +308/-574
  • Profesional Dash Stroker
« Reply #5282 on: March 15, 2016, 09:34:08 pm »
An alignment might solve it.
« Reply #5283 on: March 15, 2016, 09:36:21 pm »
Yes....but I'm guessing the car isn't pulling to either side...he likely would have mentioned that?
I suppose it could be a wheel weight has fallen off and slightly affected tire balance?
Offline Triple Bob
  • Carma: +308/-574
« Reply #5284 on: March 15, 2016, 09:38:46 pm »
Yes but if the wheels are toed in too much they can pull on the tread creating a ton of noise, but no real pull in either direction.  Check how even the wear is, are some tread blocks higher than others?
« Reply #5285 on: March 15, 2016, 09:42:15 pm »
Yes.  If it's howling, you should have uneven tread wear.
Which is why switching the tires around would help isolate the issue.
« Reply #5286 on: March 15, 2016, 09:45:05 pm »
Wear looks normal, and car tracks straight and true. Had an alignment done last spring, but the roads were horrible earlier in the winter, so I guess it could have gotten knocked out of alignment. Balance also seems fine.
My guess is that it's just whine from the winter tires. I suppose it's normal for noise to get worse as the tires wear, but it just seems odd that I'd notice it all of a sudden.
  • Carma: +471/-416
« Reply #5287 on: March 16, 2016, 08:52:09 am »
Did you get that excessive EAR WAX rinsed out...................... :-\
Offline aquadorhj
  • Carma: +271/-265
« Reply #5288 on: March 16, 2016, 09:27:56 am »
replacement rear shocks are here.  took rockauto/shipping company less than a week to send this out.
shipping was $20.
turner motorsports wants $40 to ship a freaking $4 oil drain bolt...   rockauto is the best.
« Reply #5289 on: March 16, 2016, 09:38:39 am »
shipping was $20.
Agreed. Even with exchange their prices are good, shipping is fair and fast.
LMC Truck (AKA Victoria British) charged me $20 (USD) to ship a $3 rubber bump stop for my tailgate. The thing isn't any bigger than a water bottle cap. Had to pay it too as it's sort of an obscure part and I couldn't find it anywhere else.
« Reply #5290 on: March 17, 2016, 06:00:33 pm »
Jacked it up again.  :P
Put another 400 highway kms on the GTI, and the noise is slightly worse. Also noticed that the noise goes away on right-hand highway curves, which supports my original suspicion of a bad wheel bearing on the right.
So... jacked it up again and both right bearings spin smoothly with no play. But, when I spin the rear as fast as I can get it to go, there is maybe a slight grumble to it. Maybe I'll just go ahead and replace it. ???
« Reply #5291 on: March 17, 2016, 06:01:32 pm »
shipping was $20.
Who was the shipping company?
« Reply #5292 on: March 17, 2016, 06:02:03 pm »
Did you move the tires around at all?
« Reply #5293 on: March 17, 2016, 06:07:39 pm »
No, that's too much work. :)
I won't be driving the car for a few weeks. Hopefully I'll be able to put the summers on then, which should be a good test. Won't have time to change the bearing before then anyway.
« Reply #5294 on: March 17, 2016, 06:08:38 pm »
^^Keep us posted.
On somewhat similar note, I take the LS430 in tomorrow for a 4 wheel alignment.  Hard to believe, but when I hit that racoon, my alignment went out slightly.
Offline aquadorhj
  • Carma: +271/-265
« Reply #5295 on: March 18, 2016, 12:18:17 am »
replaced rear shock absorbers.
as you can see, the old shocks are staying in whatever place i leave it at... :(  it does eventually come back.. eventually.
anyway, replace both sides, and they were both bad.
then went for a test drive.
can hardly feel the difference on normal roads, but there's a local round-about where it's bumpy continuously, and there, i can see the better damping keeping my rear end more planted.  hmm.
anyway, money well spent.
« Last Edit: March 18, 2016, 09:19:56 am by aquadorhj »
« Reply #5296 on: March 18, 2016, 08:10:30 am »
No picture on my iPad
Offline aquadorhj
  • Carma: +271/-265
« Reply #5297 on: March 18, 2016, 09:21:46 am »
attached a photo to my post.  should be able to see it.
replaced OEM Sachs shock with  Bilstein.   supposed to be stiffer than stock, but ...   i can't really feel it.
Offline Seafoam
  • Carma: +89/-202
« Reply #5298 on: March 18, 2016, 09:29:41 am »
I can see the picture.  Didn't those worn shocks wear out your tires?
2023 Honda Civic EX-B
2004 Mazdaspeed Miata
Offline aquadorhj
  • Carma: +271/-265
« Reply #5299 on: March 18, 2016, 09:37:31 am »
nah.   i can hardly feel the difference on normal commute, my previous 2 alignments were set up to minimize tire wear, too.
