Cool CarChanged oil on Legacy with Synthetic Mobile 1. First real use of Fumoto valve since install. Don't know how I survived without it. Makes job of changing oil so much easier and cleaner. Easy to remove oil if overfilled.
(Like I've never done that before ) Only wish I had the newer engine with oil filter on top. Filter below is a tight fit and required modification to oil filter remover in order to prevent oil spilling during removal.
I drilled a hole in bottom of plastic food container, just enough to allow ratchet extension to pass through. Oil ends up falling into plastic container while unscrewing it. Save messy floor since I'm using ramps and space under car is limited.
[You know for those who don't have their own hoist at home]
