Author Topic: What did you do to your car today?  (Read 3011778 times)
  • Carma: +279/-320
« Reply #3380 on: November 05, 2014, 08:58:03 pm »
On the LX570 I hit the switch to raise the truck about 3-4 inches.  Then I can just slide under and do it all.
Trucks so easy!
  • Carma: +1254/-7212
« Reply #3381 on: November 05, 2014, 08:58:34 pm »
Crazy how close/easy it is on the Forester.
Offline normancw
  • Carma: +125/-132
« Reply #3382 on: November 05, 2014, 09:00:41 pm »
Trucks so easy!
How hard is it on the Radical?
― rrocket
  • Carma: +279/-320
« Reply #3383 on: November 05, 2014, 09:04:21 pm »
Depends...  Normal changes I just suck the oil out of the dry sump container with my mightyvac.  Takes 5 min.
But yearly I need to change the filter.  Getting it off no big deal, lift car, drop undertray and pull filter and replace.
But man oh man, took me 2 hours to get the under tray back on the first time.  Haven't done it again yet lol
« Reply #3384 on: November 05, 2014, 09:05:47 pm »
2 HOURS??  WHAT ARE, YOU?  NEW??   :rofl2: :rofl: :rofl2: :rofl:
  • Carma: +279/-320
« Reply #3385 on: November 05, 2014, 09:30:45 pm »
Next time it should be 30 mins if I'm lucky.
I know the trick now.  It's quite an act.  Have to hold the entire rear undertray yourself while on your back and slide it in backwards.
Also the wheels have to be off and the front has to be jacked up enough to get the rear up high enough.
« Reply #3386 on: November 05, 2014, 09:41:05 pm »
Can't you just have your pit crew do it?   ;D
Offline blotter
  • Carma: +92/-128
  • Cars: 2014 Taco
« Reply #3387 on: November 06, 2014, 09:42:08 am »
while I don't plan to fully undercoat my truck, I do want to spray specific sections / areas under it.
anyone have a good recommendation on something I can buy from CND Tire?
  • Carma: +310/-6812
« Reply #3388 on: November 06, 2014, 10:41:46 am »
Nothing there except Rust Check and it's crap.
Stop in at a Krown Shop and either buy a can, which is large,  or they do sell it in 1 gallon pre packaged for use with a sprayer and compresses air.
Offline blotter
  • Carma: +92/-128
  • Cars: 2014 Taco
« Reply #3389 on: November 06, 2014, 11:11:54 am »
I thought they had Krown stuff on inventory as well?
thoughts on Fluid Film?  One guy I know loves the stuff
« Reply #3390 on: November 06, 2014, 11:22:42 am »
I buy this stuff from CT:
http://www.canadiantire.ca/en/pdp/rust-cure-formula-3000-0477985p.html#/en/pdp/rust-cure-formula-3000-0477985p.html#.VFuf2daP2ic
Been using it for years. Despite having the winter driven cars Krown'd every year, I use cans of this to "touch up" in key areas, usually everytime I wash the car.
Offline Arthur Dent
  • Carma: +186/-80
  • 42?
« Reply #3391 on: November 06, 2014, 11:38:28 am »
Just lean enough and long armed enough that I can do an oil change on the Corolla without raising it.
I can do my Mazda 2 without raising it either. Easiest maintenance car ever!
  • Carma: +70/-42
« Reply #3392 on: November 06, 2014, 02:16:23 pm »
Fluid Film is great, though kinda pricey.
I've been using this for the past few years as a rust inhibitor instead:
http://www.homehardware.ca/en/rec/index.htm/Hardware/Automotive/Lube-Products/Multi-purpose/Multi-purpose/400g-Multi-Purpose-Lubricant/_/N-ntjj3/Ne-lnfs/R-I8640492
Offline Julie
  • Carma: +359/-366
  • Gender: Female
« Reply #3393 on: November 06, 2014, 05:35:37 pm »
I really like Fluid Film. We Krown our cars, but use Fluid Film to touch up or do smaller areas by hand. Mostly on the 10-year Miata, because that's the vehicle that needs some parts to be done by hand (e.g. metal bolts under the car seats). On some parts of the car where I've used it , I've sanded off the rust before applying the Fluid Film, and the bare metal hasn't developed rust yet. You can also apply directly without sanding off the rust first. I've seen no further development of rust in such areas either.
Offline normancw
  • Carma: +125/-132
« Reply #3394 on: November 07, 2014, 08:06:31 pm »
I bought this for it from Princess Auto
Offline Railton
  • Carma: +243/-156
« Reply #3395 on: November 08, 2014, 06:59:44 pm »
Snows are on. This will be the 5th Winter season for the G. Time flies.
Railton
« Reply #3396 on: November 08, 2014, 08:40:09 pm »
Put the winter tires on the Yukon today. Got the two back ones on, then remembered they are directional. Crossed my fingers and took a look - of course they were both on the wrong way. D'oh!
« Reply #3397 on: November 08, 2014, 08:59:03 pm »
Highlander and Corolla stayed home. Took the Subaru today as it's the first real snow of the season and it's been carnage on the roads. Subaru + Blizzaks, yeah baby!!!
  • Carma: +279/-320
« Reply #3398 on: November 08, 2014, 09:00:46 pm »
I drove the LX around the block, first time it has run in a week... And I want another car lol.
Tomorrow she tows our race car to storage.
Offline Solstice2006
  • Carma: +245/-468
« Reply #3399 on: November 08, 2014, 09:24:57 pm »
Picked up the Mazda6 today, while dropping off the Mazda5 at the dealership, took a corner so fast ,with the roads quite wet, nearly ended up sideways!  ;D
Will post some pics when I can, drove 75 km today already.
