Author Topic: What did you do to your car today?  (Read 3014129 times)
Offline CanuckS2K
  • Carma: +398/-316
    • Prestige Auto Detail
« Reply #2620 on: June 03, 2014, 08:42:40 pm »
Replaced the HU and stock speakers in the S2000 today and the difference is incredible.  Unbelievable how shitty the stock speakers in the S2000 are.   Snowy, definitely worth upgrading man!
  • Carma: +1254/-7213
« Reply #2621 on: June 03, 2014, 08:47:25 pm »
Pics?  Or not much to see?
Offline CanuckS2K
  • Carma: +398/-316
« Reply #2622 on: June 03, 2014, 09:11:54 pm »
Nah, no pics as everything looks the exact same.  Having USB and Satellite radio will be a nice addition, especially since I'm taking it to Portland this weekend.   Now, just want to sell my existing JVC HU unit with built in Navi and HDD.
Offline aquadorhj
  • Carma: +271/-265
« Reply #2623 on: June 03, 2014, 09:53:30 pm »
bought some touch up paint.
« Reply #2624 on: June 03, 2014, 10:40:30 pm »
Got caught in the rain with the SLK, so gave it a wash when I got home. Haven't seen it without a thick layer of garage dust on it in awhile:
Offline CanuckS2K
  • Carma: +398/-316
« Reply #2625 on: June 03, 2014, 10:42:56 pm »
 :thumbup: :thumbup: :thumbup:
  • Carma: +1424/-2121
« Reply #2626 on: June 03, 2014, 10:46:58 pm »
SO got a leak in the gas tank, went to drop it to change the seal from the filler spout and forgot that the jack failed a little while ago....le sigh....off to Canadian Tire tomorrow.
« Reply #2627 on: June 03, 2014, 10:47:47 pm »
No bottle jacks or the OEM jack in either car?  Works in a pinch!
« Reply #2628 on: June 03, 2014, 10:52:10 pm »
Yeah, but the floor jack reaches higher, when youre by yourself its easier.....and like all the bloody times Ive worked on a tank....its at least 3/4 full  :(
« Reply #2629 on: June 03, 2014, 10:52:53 pm »
You sure it's 3/4 full?  Flip you lighter on and have a quick look inside.... ;)
« Reply #2630 on: June 03, 2014, 10:53:50 pm »
Lighter, Im a man, if Im gonna go out, its gonna be with a flare  ;D
Offline Sir Osis of Liver
  • Carma: +1376/-1726
  • Ramblin' man
« Reply #2631 on: June 04, 2014, 12:11:46 am »
After all the Subaru oil consumption chatter, I checked the oil. 7K on this fill and it's still bang on the full dot.
H. L. Mencken
Offline tooscoops
  • Carma: +325/-227
  • "stealership" employee
« Reply #2632 on: June 04, 2014, 09:55:39 am »
did a test on the Jeep... roof down, i got 14.1l/100 for my drive home driveway to driveway... roof up, 12.7l/100...
now just to fine tune my driving habits to get that down a bit.
Offline Wolverine
  • Carma: +2/-0
  • Cars: Ford Focus sedan 2008 1.6 Flexfuel
« Reply #2633 on: June 04, 2014, 09:24:53 pm »
Productive sunday.
Replaced front rotors and brake pads,  EBC Green stuff.
Also installed an anti-sway bar, made by a friend specially for my car.  Those on the market do not fit the Focus with a 1.6L flex engine. Installed NGK Iridium spark plugs, old ones had 55k km on them.
Please don't mind doing that the car is REAAALLY dirty.
"If you wanna make the world a better place take a look at yourself and make a change."
« Reply #2634 on: June 04, 2014, 11:44:01 pm »
So I got my air con delete kit, the compressor was leaking and making a horrid sound and when I went to get the system drained the guy found nothing. It was fairly easy, cut the lines with with a bolt cutter, take the condenser, evaporator and compressor out and install new pulley. Took me about an hour, hardest part was the condenser as I didn't want to drain the rad....because lazy.
Also installed new pedals and a new coil pack
Sent from my Galaxy S3
Offline aquadorhj
  • Carma: +271/-265
« Reply #2635 on: June 05, 2014, 12:09:24 am »
cool,  for which car!?
« Reply #2636 on: June 05, 2014, 12:11:24 am »
The Mustang.....after I stick the battery in the trunk that will be 80-100lbs out of the nose.
Offline X-Traction
  • Carma: +58/-96
« Reply #2637 on: June 05, 2014, 01:58:56 am »
In the latter stages of fixing all the ways Escape rear hatches can leak, today I replaced the weatherstripping around the hatch glass opening.  Because the strip is one loop, this requires either removing the hatch glass's hinges, or removing all the wiring plus the struts.  I chose the latter.  It also requires removing the inner trim panel from the hatch, but I've had lots of practice doing that.
Since the pinchweld for the opening has many irregularities, I filled the slot in the rubber weatherstrip with windshield adhesive before installing it.  If and when this weatherstrip leaks, the water ends up in the cargo area and causes all sorts of mischief.  This is a bit of an awkward job with the heavy hatch glass flapping around.
I also installed transparent protective film on the 6 places on the hatch where my bike rack's straps attach. This will protect the paint.
Started working on installing sound deadener in the doors, but got stopped because it requires a T30 screwdriver to remove the inner door panels.
« Reply #2638 on: June 05, 2014, 02:19:40 am »
Bummer when you have to stop because missing tool...
« Reply #2639 on: June 05, 2014, 02:41:40 am »
Yeah, that definitely sucks man...I hate that.
