Author Topic: What did you do to your car today?  (Read 3043350 times)
Offline sailor723
  • Carma: +416/-1000
« Reply #18780 on: January 14, 2024, 04:16:14 pm »
So, I’m more than a little pissed to discover the Crosstrek’s block heater isn’t working. Thought I just hadn’t plugged it in properly, but nope. Open circuit when tested with a multi meter, so seems the thing is dead.  >:(
Minus 32 when I started it on Friday. Minus 25 when I started it yesterday. It was painful to listen to each time, but it did start.
Don’t want to make a trip to the dealer, and also don’t want to investigate further in my driveway at minus 25.  ::)
A block heater is something you don't want to be without.
I've actually never had one in nearly 48 years of car ownership.   ???
  • Carma: +391/-634
« Reply #18781 on: January 14, 2024, 04:49:42 pm »
I'm now living by the lake and I have a very steep but short access road to drive up to the main road. Thanks to a shift in the wind last night we got a lot of lake effect snow and the access road is snow covered and very slippery. Took me 3 attempts to get up it this morning, have to love one wheel drive. Might have to trade in for a Subaru if this weather keeps up.
Even saw a few pickups in 4x struggling up. Still waiting for the Cybertruck to come by and show everybody how it is done.  :rofl2:
  • Carma: +1254/-7214
« Reply #18782 on: January 14, 2024, 05:34:54 pm »
Yeah, I’m not happy.
I did take another quick look just now, but you can’t see anything from the top side. Would have to pull off the plastic undertray and look from the bottom.
I guess I’ll call the dealer tomorrow and make an appointment. It’ll probably be two weeks before they get me in, and by then it will probably be plus 5 again.   ::)
I just looked at their online service scheduler: first available appointment is January 30.  ::) ::)
Check the fuse?
« Reply #18783 on: January 14, 2024, 05:36:10 pm »
One wheel drive, are you still riding a bicycle?   :D
Drop tire pressure on the driving wheels, it should help a little.
  • Carma: +391/-634
« Reply #18784 on: January 14, 2024, 05:50:00 pm »
I would have made it up first try on my bike as I run studded tires.
So drop the tire pressure, drive 25m up the hill, stop, pump up tire pressure?  Think I'll stick with a longer run before the hill to gain some speed and hope for no cross traffic.
« Reply #18785 on: January 14, 2024, 06:03:40 pm »
Check the fuse?
If there’s a fuse, it must be at the block heater end. There’s nothing in the cord near the plug end.
So, back to the original problem: without jacking up the car and removing undertray, can’t see anything beyond the plug and the first three inches of cord.
« Reply #18786 on: January 14, 2024, 06:21:49 pm »
I had a set of strap type tire chains (the kind that wrap through the rim) for that type of thing when I was driving 2WD vehicles. Was a huge help in low speed no traction situations
  • Carma: +309/-518
« Reply #18787 on: January 14, 2024, 06:22:02 pm »
Reverse up the hill, puts more weight on the front tires & they now push up instead of pulling as the weight transfers back going forwards.
« Reply #18788 on: January 14, 2024, 08:09:38 pm »
You forget the e-brake part at the top of the hill so your're all turned around when you park!! LOL [emoji38]
  • Carma: +309/-518
« Reply #18789 on: January 14, 2024, 08:16:47 pm »
No handbrake required in reverse, Rockford turn at the top :skid:
« Reply #18790 on: January 14, 2024, 10:23:17 pm »
I meant if it e.g. says 33psi on the door jamb, I'd run it at 30-31 psi for as long as it's slippery there. It will reduce the gas mileage and wear the tires a bit more but will improve traction, especially in fresh snow.
« Reply #18791 on: January 14, 2024, 10:42:16 pm »
You will see zero difference with a mere 2-3 psi change in winter.
Old wives tale.
  • Carma: +232/-1073
« Reply #18792 on: January 14, 2024, 10:45:48 pm »
This. Ran into a similar situation at a friends cottage one year, got snowed in good overnight. We had some FWD unit, Intrepid maybe (wasn't mine) and after a few failed attempts the reversing trick worked well.
« Reply #18793 on: January 15, 2024, 12:40:31 am »
Check the fuse?
They are not that complicated. I bet the cord end towards the engine wasn't pushed onto the connectors hard enough. Or they didn't install it and all you have is a cord. Either way would show open circuit?
Offline sailor723
  • Carma: +416/-1000
« Reply #18794 on: January 15, 2024, 07:27:27 am »
Question for you guys that regularly need block heaters. Do you also use one of those battery warmer covers?  What about leaving a trickle charger on? Would that help?
Offline bridgecity
  • Carma: +126/-182
  • Cars: 2014 MDX; 2007 Tundra
« Reply #18795 on: January 15, 2024, 07:45:20 am »
No battery blankets on our vehicles, although I imagine it would help prevent dead batteries. I’ve heard plenty of stories over the last few days of new vehicles not starting after sitting outside overnight. Batteries are dead, killed by the cold. A quick boost and they’re off to the races, until sitting overnight in the cold again.
« Reply #18796 on: January 15, 2024, 09:56:53 am »
Our RX doesn't have a block heater, it's always started but but I'll put the battery on trickle charge when it's very cold and that does seem to help. Will sometimes get the oddball low battery messages otherwise too when it's very cold
« Reply #18797 on: January 15, 2024, 10:11:28 am »
So much stress starting engine at -30. Yes it starts but at what cost? Block heater gets that coolant and then oil warm.
Offline Bubba
  • Carma: +382/-442
    • My photo site
« Reply #18798 on: January 15, 2024, 02:34:16 pm »
Started my car at -24C air temp yesterday; coolant was +10C.  Block heater was doing its job.
Offline erich
  • Carma: +36/-125
  • Cars: current: 2023 Genesis G70 2.0t,2019 Infiniti QX50, previous:2017 Subaru Legacy, 2014 Mazda CX-5, 2012 Genesis Coupe 2.0T, 2010 Subaru Forrester, 2004 Honda Civic, 2000 SAAB 9-3, 2000 Dodge Caravan, 2000 VW Golf, 1996 Suzuki Baleno, 1990 Subary Justy 1.0GL
« Reply #18799 on: January 15, 2024, 02:56:48 pm »
After a day parked outside at work, the block heater makes a big difference in how soon the  heating comes on
