Author Topic: What did you do to your car today?  (Read 3043718 times)
  • Carma: +244/-779
« Reply #17640 on: April 11, 2023, 04:25:20 pm »
Yes LR4 still uses a semi metallic pad which is why most Land Rovers  have black front wheels.  ;D  I can get 2 sets of pads on those rotors (OE(Brembo) or Zimmermann) but then the rotors are too thin. Honda rotors last much longer but pads are not as aggressive. A tip on getting the rotor screw out is to tighten the screw a bit first and then loosen. Also slather some breaker spray (of your choice) and a little torch heat. If you don't have an impact then tap a driver with a mallet as you are trying to break it free. Using this method I have a 100% success rate.
As a side note for fun my Ridgeline consumes rear brake pads much faster than fronts. I attributed it to the stability control trying to reel in a prick but others have mentioned it may be just a weird brake proportioning on light stops.
^ It think it's probably a bit of both contributing to the rear pad consumption. Escalade is the same, I replace the rears 2x for every 1 set of front.
Do they use brakes for traction control?   That'll wear 'em out
Offline Arthur Dent
  • Carma: +186/-80
  • 42?
« Reply #17641 on: April 11, 2023, 04:46:04 pm »
Our Nissan Quest was like that. It had tiny, tiny rear brakes. Not sure if that contributed. They warped really easy too.
Online Firm
  • Carma: +232/-1073
« Reply #17642 on: April 11, 2023, 04:54:10 pm »
Yeah, they do. Traction/stability control usually leverages the brakes.
Offline Seafoam
  • Carma: +89/-202
« Reply #17643 on: April 11, 2023, 07:17:24 pm »
^yep!
First time I eventually got them out with an impact driver. 2nd time, just drilled them all out. The Acadia has the rotor screws as well...
I changed the rotors for the first time on the Civic at around 160,000 km and 10 years. The impact driver worked but it took a bit of effort to break them loose. Still  on the second set of pads since new.
2023 Honda Civic EX-B
2004 Mazdaspeed Miata
Offline KD
  • Carma: +359/-263
« Reply #17644 on: April 11, 2023, 07:22:07 pm »
^ Rear pads on our GS-350 wear out faster than the fronts as well.
While cleaning the GS-350 last weekend I noticed over half of the retainer clips for the engine shroud covers were missing. Many of the remaining ones are broken and won't last for much longer either.  Really shitty design and I've replaced many in the past with aftermarket ones, but they were even worse, and only one if them survived.  A few have gone missing from the under-body panels and I replaced them with cable ties but I'd like to keep reusable ones for the engine shrouds.
Think I bought the last set from Princess Auto but they were junk.  Any ideas on where I could find some decent ones?
  • Carma: +310/-6813
« Reply #17645 on: April 11, 2023, 07:40:58 pm »
At 35K km the Armada got full set of pads and rotors on Nissan.  Paid the 1 hour brake service charge.  At 6000 lbs. the rotors look too small for the vehicle of that weight.  Will be paying Nissan every year to do their brake service in the spring.
The Mustang has 40K km and nil wear.  IMO, the salt which is extreme in my driving area is the contributing factor; seizes the pads if your vehicle has floating pads which most do.
Offline Dante
  • Carma: +33/-97
« Reply #17646 on: April 11, 2023, 08:22:04 pm »
I buy them from the dealer. Bought few different kinds off Amazon and they are junk ...
Offline bridgecity
  • Carma: +126/-182
  • Cars: 2014 MDX; 2007 Tundra
« Reply #17647 on: April 11, 2023, 08:40:32 pm »
Dealer for push pins?? Meh. Bought a huge kit with hundreds of push pins, about 25 different styles, for about $30 off Amazon. Work fine, and when one does need replacing you’ve got many different sizes/styles at your disposal. The kit has paid for itself many times over already.
Online Firm
  • Carma: +232/-1073
« Reply #17648 on: April 11, 2023, 08:50:44 pm »
That's what I have, one of those huge kits off Amazon, use it quite frequently.
Offline KD
  • Carma: +359/-263
« Reply #17649 on: April 11, 2023, 09:36:31 pm »
Order placed!  :thumbup:
« Reply #17650 on: April 11, 2023, 11:17:45 pm »
Also look for a large kit of aluminum crush washers. I bought a kit of 470. 18 different sizes M6 to M24 for $26.  Honda sells one for $4.  ;D I have a ten lifetime supply...
ALso a kit of 200 copper washers. Same deal.. ;D
  • Carma: +1254/-7214
« Reply #17651 on: April 12, 2023, 11:40:31 am »
There 2 kind of phillips!?  I hate those,
There are a few different drives that look like Phillips, but aren't.
If you're working on a Japanese anything, especially motorcycles, get a JIS set of screwdrivers and stop stripping screws.
https://www.amazon.ca/Bessel-Vessel-Difference-Screwdrivers-No-220w-3/dp/B00E55DL4I
This
« Reply #17652 on: April 12, 2023, 11:45:20 am »
Everyone should just stop using phillips period whether it is JIS or not.
Torx and hex.
Offline WP v3.32
  • Carma: +8/-18
  • Cars: 2022 Ram 1500 Classic, 2014 Highlander Hybrid
« Reply #17653 on: April 12, 2023, 02:19:03 pm »
Torx and hex.
butterfnife is my main screwdriver anyway
  • Carma: +269/-457
« Reply #17654 on: April 12, 2023, 02:22:47 pm »
Torx and hex.
I've always just used my fingernails.
« Reply #17655 on: April 12, 2023, 02:32:02 pm »
Hate torx with a passion. A million different sizes, tiny little flutes, seems to do nothing that a hex doesn't do better
Apparently the original idea behind it was as an anti theft hex, as an ordinary hex bit does not work
Online Firm
  • Carma: +232/-1073
« Reply #17656 on: April 12, 2023, 02:58:25 pm »
Same, Torx sucks. Philips works for me from a function / aesthetics combo, it's just a matter of finding the right screwdriver with a nice tight fit, lots of variability between brands and such. Robertson and Hex works best, but looks terrible.
  • Carma: +1424/-2122
« Reply #17657 on: April 12, 2023, 03:00:28 pm »
Put me in the BOO torx BOO category. My favorite screwhead is a socket head  ;D
  • Carma: +309/-518
« Reply #17658 on: April 12, 2023, 03:48:04 pm »
White appliance today with help from Son #2.
After reading KTM & Firm's posts on rear brakes, gave the rears a close inspection, will need to be done shortly. Definitely before we head to PEI in August.
Offline bridgecity
  • Carma: +126/-182
« Reply #17659 on: April 12, 2023, 04:00:12 pm »
Nice.
How many km's you have on that thing?  Pads on our MDX have a lot of life left front and rear with 125k kms.  Our '03 Pilot went to 175k km's before I did the rear.  I did the rears on the Tundra at about the same, fronts went longer.
