Some more cosmetic work done on the BMW:
- replaced weather strips at the top of the windshield and around rear window - all went well except that in the front I found some broken paint and some superficial rust lines in the channel in both corners where the paint was broken. Had to clean the rust and touch up the paint (I used Rust Check rust paint for that and it blended in pretty well).
- cleaned up (again) the headlights, this time with the 3M kit which worked better than Meguier's IMO still not 100% but I can definitely live with the result (I think some hazing is inside). Still need to make another try as I screwed up a little the clear coat application on one side
- had the steering wheel refinished (was showing some excessive wear on the top side); while not perfect it looks good and passable.
The bummer is that I have to re-paint the front bumper as the clear coat peeled off on a large area when I removed the masking tape around the left headlight. This was unplanned and it will set me back $600...
Still quite a bit of work left but I kind of lost some enthusiasm.... but I need/want to get to the end of job.
