Author Topic: What did you do to your car today?  (Read 3008869 times)
« Reply #14520 on: April 27, 2021, 05:23:46 pm »
It makes kind of a hard coating, not sure how well it lasts
I've had good luck with POR instead, using a kit with the metal prep
« Reply #14521 on: April 27, 2021, 05:40:20 pm »
Whoohoo!  Truck "oil leak" wasn't the turbos!  Valve cover gasket and the vacuum pump or something...under $200ish for parts, way less labour than the turbo's would've been.  Also had them to a filter/trans flush and refill and transfer case fluid replacement.   ;D  Yay!!
Next project: get the cab corners fixed up.  Just have to decide if I do it cheap (local shop or maybe fiberglass and you tube tutorials! lol) or not cheap (cut out and full replacement).
Anyone ever used phosphoric acid on rust?  Can you paint right over it or does it need to be washed off after you've dissolved all the rust (thinking of the back of the rocker panels).
My dad used to use raw phosphoric acid, seemed to work fine. I use the branded 'rust converter' for whatever it's called (I am pretty sure it's just phosphoric acid, smells like it), that one claims you can prime right over it after it's dried.
Offline Triple Bob
  • Carma: +308/-574
  • Profesional Dash Stroker
« Reply #14522 on: April 27, 2021, 05:41:58 pm »
I have a couple of small rust spots on the edge of the doors that I wanted to treat somehow, sand / paint? What's the best way to do it?  I don't mind if the paint isn't 100%, it's getting wrapped anyway.
« Reply #14523 on: April 27, 2021, 07:59:35 pm »
Post a pic, hard to give you any decent direction on how to handle it without seeing it.
« Reply #14524 on: April 27, 2021, 08:06:00 pm »
Yesterday I grab the CT Ram 1500 from the corp facility where it was sitting since Covid hit in March 2020. Left the DTS there and will use the Ram for a few weeks since I am working on a landscape project at home and need a proper pickup bed. Old girl fired right up after sitting untouched for 15 months...It's a great truck, but driving it really makes just about anything else feel super refined.
Offline me_2
  • Carma: +300/-76
« Reply #14525 on: April 27, 2021, 08:13:13 pm »
Were the brake discs rusty (at least grumpy) after sitting for so long?
  • Carma: +308/-518
« Reply #14526 on: April 27, 2021, 08:15:07 pm »
Yeah, I was thinking the same thing, but then am guessing this was stored indoors & that made for less issues.
« Reply #14527 on: April 27, 2021, 08:21:20 pm »
Yeah, it was indoors in a heated/ventilated shop. No rotor corrosion or anything that I noticed. It does have a nice set of PowerStop brakes as well, which are Zinc coated and really helps keep the corrosion down (on the non-contact surfaces at least)
Offline me_2
  • Carma: +300/-76
« Reply #14528 on: April 27, 2021, 08:31:56 pm »
Ok, it makes sense since it is a garage queen  :rofl2: (no offence)
I'm asking because most EVs with dynamic braking, the friction brake are much less solicited if compared to ICE, so an annual brake cleaning/lubrification is mandatory to avoid premature brake replacement due being rusted or uneven wear out...
« Reply #14529 on: April 27, 2021, 08:45:13 pm »
Yeah, that's an issue for sure. Pad separation (where the friction material separates from the backing plate) was a significant issue on some EVs, Toyota I think, because the pads rarely got warm enough to get the moisture out.
There's a Toronto based company that makes Galvanized backing plates to avoid that and they have a bit of a niche following with EV owners:
https://www.canadiantire.ca/en/pdp/nrs-brakes-galvanized-brake-pads-2162700p.html
Offline me_2
  • Carma: +300/-76
« Reply #14530 on: April 27, 2021, 08:54:26 pm »
I tried Volt Gen 1 (2014) & Gen 2 (2019) nope, not yet...  :P
Offline BWII
  • Carma: +188/-376
« Reply #14531 on: April 27, 2021, 11:40:29 pm »
Don't know why I didn't think of that.  Probably easier than trying to get rid of the rust and spraying box liner over it.  Might even last longer...could probably do box liner over POR too.  Double protection.
Cdn Tire sell it?  Guess I could look, see if it's on the website eh?  :P :bang:
Offline BWII
  • Carma: +188/-376
« Reply #14532 on: April 28, 2021, 05:43:16 pm »
Well not as low as I thought all things considered, then again I had no idea how many litres of trans fluid were needed, how much the new filter screen was...still cheaper than turbo seals etc.  I wonder if the dealer would've charged labour for both the trans/valve cover separately too...probably. And these guys are $45/hr cheaper than the dealer.
Probably added another 10 yrs to its life.  ;D
Offline JohnnyMac
  • Carma: +111/-460
« Reply #14533 on: April 28, 2021, 05:46:50 pm »
That’s not terrible considering you likely won’t have to do that again.
Offline BWII
  • Carma: +188/-376
« Reply #14534 on: April 28, 2021, 05:49:33 pm »
Found out too that the turbos on the 2013 were updated and not as prone to shi#ting the bed like 11-12's.  Fingers crossed!
  • Carma: +391/-634
« Reply #14535 on: April 28, 2021, 06:13:43 pm »
14L of ATF? Is that average, high, or low in the world of trucks?
  • Carma: +1424/-2121
« Reply #14536 on: April 28, 2021, 06:17:13 pm »
My GM trucks were like 6-8L....that seems like a lot, but that also includes the cooler and lines
Offline jamie1
  • Carma: +22/-20
« Reply #14537 on: April 28, 2021, 11:15:21 pm »
He had the transmission flushed. 14L would be about right.
  • Carma: +268/-457
« Reply #14538 on: April 29, 2021, 08:22:10 am »
Took the Civic for an oil change last week at my cheap Indy (I have two Indy's I go to - a cheap one for the Civic, and an expensive one for the Tundra).  $45 for a conventional oil/filter change.  I considered doing it myself, but then realized that I'd just end up with a huge mess on my driveway, and figured its easier to just drop the car off.  The shop is a 5 minute walk away from my work, so it's awfully convenient.
That's now nothing but oil changes and tires for the Civic since we got it safetied over a year ago.  It's a great little beater.
  • Carma: +308/-518
« Reply #14539 on: April 29, 2021, 09:16:31 am »
Yeah, at that price I ain't crawling under the car to do an oil change  :rofl2:
Glad it's working out for you!  :cheers:
