Author Topic: What did you do to your car today?  (Read 3010786 times)
« Reply #13500 on: October 21, 2020, 04:18:45 pm »
and again as we have talked before...how often are you playing with your coolant that this actually is a thing to be concerned about?
My coolant gets touched every 2 for green, every 5 years for other colours. Just get premixed unless you are doing a flush every....lots of years.
If you are playing with coolant more than that...there is something wrong with your car?  :P
I usually do every 3 years, on my 8 car fleet that's 2.5 coolant changes per year....excluding projects/flip cars. If I save two $20 jugs per change by using the concentrate and mixing myself that's $100/yr....I'll take that. It's also just how I am, I apply that sort of logic to everything....
Offline ChaosphereIX
  • Carma: +187/-377
  • Wont run with the pack
  • Cars: 2015 Jaguar XJR-L
« Reply #13501 on: October 21, 2020, 04:20:57 pm »
But you are basically a small vehicular museum Firm...I understand you are dealing with saving money though bulk  ;)
« Reply #13502 on: October 21, 2020, 06:26:13 pm »
Whatever man, the salt lamp was tongue in cheek obviously. Pat Goss says either type of water is fine:
https://www.youtube.com/watch?v=ZyJ657cQh2Q
I've used well water garden hose and the green stuff for decades on my former Detroit metal.  But those machines were simple.  Heater cores with AC where still wickedly difficult to replace but doable, but now Ford for example on many units combines the heater core, evaporator and blower fans in one pre assembled unit.  That's the point of me changing the fluid on such a low mileage vehicle that is to attempt to try and avoid any acidic issues and what not in the cooling system.
Same logic ppl use when changing motor oil before season storage.  Supposedly to avoid excess acids.  Does it matter  ???  Does it matter materially?  Who knows, but each to his own.
As for the de ionized water why not?  I'm not spending $38 a gallon on coolant concentrate to cheap out on the water.  It's $4.00 per gallon  ::).  I didn't think the cost of the stuff was such an issue with ppl.  :)
The issue is not the cost but you yelling to "NEVER" use distilled water.  ::)
Offline Scaerio
  • Carma: +193/-127
« Reply #13503 on: October 21, 2020, 07:08:09 pm »
I change my cars more often than my coolant.  ;D
This is one of the many reasons why you are one of the heroes of the forums.
  • Carma: +310/-6812
« Reply #13504 on: October 21, 2020, 07:11:06 pm »
It's always the same on this site; the misrepresentation of what ppl actually say.  :P
I simply posted that I was changing my coolant out and that Crappy was short 2 gallons of de-ionized water.  That's it.  Not telling ppl what to use.  This is what I was doing.  Then I have ppl jumping in saying distilled water is better because of the price.  That I can go to a supermarket and get for cheap.  Well I don't go to supermarkets and standing in covid lines and I don't care about $3 extra a gallon.
That was the size of it.  I posted a quick google search on why I use what I bought and all hell breaks loose about it.  Such blatant misrepresentation about this very insignificant matter.
  • Carma: +310/-6812
« Reply #13505 on: October 21, 2020, 07:25:00 pm »
Why not just get the pre-mixed coolant? Like this? https://www.canadiantire.ca/en/pdp/prestone-all-vehicles-antifreeze-coolant-3-78-l-0293023p.html
Simple.  To evacuate all the old coolant out of the block and heater core it takes a lot of water and many drain and fill cycles to rid the system of the original coolant.  The goal is to essentially have the system all water.  Please no one bring up what kind of water.  :P  So now you have system that is all water and then you do your last drain.  Generally one is going to get 50% of the "water" out of the system.  At which point you add the concentrated coolant to the system and generally achieve the 50/50 mix.  That can't be done with premix coolant.
What is a drain and fill cycle:  4 times.   That would require a crazy amount of premix.  :)
  • Carma: +308/-518
« Reply #13506 on: October 21, 2020, 08:03:19 pm »
Simple.  To evacuate all the old coolant out of the block and heater core it takes a lot of water and many drain and fill cycles to rid the system of the original coolant.  The goal is to essentially have the system all water.  Please no one bring up what kind of water.  [emoji14]  So now you have system that is all water and then you do your last drain.  Generally one is going to get 50% of the "water" out of the system.  At which point you add the concentrated coolant to the system and generally achieve the 50/50 mix.  That can't be done with premix coolant.
Ahhh, gotchya now... makes sense.
Offline JohnnyMac
  • Carma: +111/-460
« Reply #13507 on: October 22, 2020, 08:10:25 am »
I guess I must be a bad car owner as I've never changed the coolant on any of our vehicles.  Had the Hyundai Santa Fe for over 10 years and only topped it up once with premix.  Never had any issues.
I guess the Golf R did have some of it's coolant changed when they did the turbo job under warranty.
  • Carma: +268/-457
« Reply #13508 on: October 22, 2020, 09:14:34 am »
Coolant in the Tundra doesn't get replaced until 10 years or 160k kms.  I probably won't hit the mileage in that time, so I guess 8 more years it is.
Online tortoise
« Reply #13509 on: October 22, 2020, 09:40:42 am »
Yeah, the TDI VW forums say to change the coolant at 180k km when you do the timing belt.
That said, VW TDIs seem to be prone to clogging the heater core due to the EGR system getting really hot (I think during a regen).  So it might be worth doing it at 100k km or so.
Offline TheHire
  • Carma: +103/-403
  • Manual Preservation Officer
    • DoubleClutch.ca Magazine
« Reply #13510 on: October 22, 2020, 09:43:44 am »
Doesn't Amsoil make coolant?  ;D
I assume it's lifetime, just like their oil change interval recommendations...  :rofl2:
Offline draghon
  • Carma: +20/-27
« Reply #13511 on: October 22, 2020, 10:34:46 am »
Maintenance minder on the civic called for a coolant change at 160k, right around the 10 year mark for me. Had an indy shop do it as it was in the middle of winter.
The Acadia owners manual says coolant change is not required until 240k! Might tackle that one ahead of schedule...
ex rides: 93 Aerostar XLT AWD
  • Carma: +1254/-7211
« Reply #13512 on: October 22, 2020, 02:47:27 pm »
Yep...but in this case, coolant is just coolant.
Which, obviously differs from oil.
Lifetime...LOL [emoji38]
Offline Blueprint
  • Carma: +170/-232
  • member since way back when
« Reply #13513 on: October 22, 2020, 03:27:57 pm »
Plugged the TR6's new battery maintainer, NOCO Genius 1, before it drains down. Battery unplugged because of hanging wires - parts just flew out of LAX according to my USPS updates. Washed the car with "Sanszo" waterless car wash during my lunch break - so shiny now  :love: Damn this winter's going to be long!
Offline Arthur Dent
  • Carma: +186/-80
  • 42?
« Reply #13514 on: October 22, 2020, 06:00:28 pm »
My boy has been driving it to school since the Fiero only has all seasons. A Ford Probe owner apparently commented on how cool it is.  :rofl2:
Offline TheHire
  • Carma: +103/-403
« Reply #13515 on: October 22, 2020, 06:06:05 pm »
Is that seriously how much snow you people have right now?!  :o :o :o
Meanwhile I'm sitting here tinkering with the idea of when over the next two weeks am I going to put the Aston and M5 away...
I stored the S2000 last weekend since it only got ~200-300km of driving this season.
Offline Arthur Dent
  • Carma: +186/-80
  • 42?
« Reply #13516 on: October 22, 2020, 06:11:51 pm »
We have had snow melt already! Had maybe 8 inches.
Offline Scaerio
  • Carma: +193/-127
« Reply #13517 on: October 22, 2020, 06:36:57 pm »
I could use 8"...
Oh, you mean snow!
 :banana:  ;D
« Reply #13518 on: October 22, 2020, 08:44:17 pm »
 :pimp: Why can't you be my neighbor?
Offline Arthur Dent
  • Carma: +186/-80
  • 42?
« Reply #13519 on: October 22, 2020, 10:05:04 pm »
Firm - I'd love to be your neighbor. I think we would get along fantastically.  :love: :thumbup:
Scaerio - best of luck finding your 8"  ;D
