Author Topic: What did you do to your car today?  (Read 3012187 times)
« Reply #12800 on: June 16, 2020, 03:51:31 pm »
I've seen it said the Ford cam phaser issues are mostly a side effect of not enough oil flow to the head.
Combo of small oil passages that clog easily and leaky seals on the time chain tensioner assembly that bleed pressure
  • Carma: +1424/-2121
« Reply #12801 on: June 16, 2020, 03:54:09 pm »
Ive heard a stop gap measure is a higher flow oil pump to make up for the lack of engineering.
Offline BWII
  • Carma: +188/-376
« Reply #12802 on: June 17, 2020, 01:28:26 am »
Oh but for the lack of power...an unboxed frame...and the horrible fuel mileage.  I think with a trailer like mine, it would suck a Tundra down to 4 mpg.  Then again...my BIL has had his for oh it's gotta be 10 yrs now, engine was replaced under warranty early on...and it's an ugly sandstone 2wd and he tows a 34' (!!!) monster with it all over the place.  BC, Ontario, Wyoming, Texas...and yet it still does it.  Next time I see him - could be years from now, now, who knows, despite them being in Niverville - I'll have to ask.  He should really have a 3/4 ton for his trailer, but somehow it does it without breaking.  Not that mine's broken per se...and I love the turbo pull compared to an NA 8, no comparison, but this is kinda stupid on Ford's part.  It's as if Apple owns most of the shares...made to die.
381hp and 401ft-lbs of torque aren't enough for you?
And who says that a fully boxed frame is a necessity for a half-ton truck?  There is so much more to it than that.  Type and thickness of steel, the dimensions of the frame, number/size of crossmembers etc.  Just saying 'fully boxed frame' means squat without all the other information.  A great example to support my argument is that most commercial trucks use open C-channel frame, including Ford's own F-550 truck.  Fully boxed frame is just a nice thing to say when marketing the truck.  Ultimately, as long as the frame is designed to resist the forces placed upon it, who cares whether it's fully boxed or open C-channel, as long as it does the job that is asked of it.
Fuel economy...don't use my truck's numbers, they're skewed by short trips.  Overall the Tundra isn't that much worse than your very own F-150 with the older 3.5EB.  And it certainly won't need to go into the shop for cam-phaser maintenance every second year.
The fact that the Tundra is such a known quality product would make it my no brainer 1/2 ton choice. Even being a GM guy, I know that the Tundra will be buried with me which for a truck, is my main concern.
But then I'd have no reason to want a new truck again, would I?  ;D
It's probably enough, it's just an N/A V8 doesn't have the low down punch in the torque pants the E/B does...and you can't get a real bed on a Tundra either.  Not with the full 4 door anyway.  6 and a half or nothing.  Need a place for the dog, 4 bikes, fire wood...all sorts of stuff you don't want in the camper or in the truck.  I also totally get sucked in to the boxed frame thing.  It's just better, right?  Overall an F150 is just a better truck. (watch the links first please)
I've said many times on here what I get towing my 31' trailer, and I don't think its any worse than you BW.  Typical day would be 25-26l/100km, with a range from 22-32 depending on the wind.
We're heading to Falcon Lake over Canada Day...I don't think I'll get 26 with the trailer.  But we fill both water tanks to the brim so I'm dragging whatever that sloshy stuff weighs along with us.  I'll try to keep an eye on it though, what with the brand new chain and all, I'll probably pick up like 6l/100!! (hahaha...someone's gonna read that and make it real...it's fake news kids... ::) ;D)
I wonder why the dealer wouldn't know this...and then why wouldn't they just put one in?  No idea where it might be on the engine in this case, but if it's in the front of the block, why not also include that in the fix-it-kit?  They just put a new water pump on without calling me.  It was showing signs of leaking through the weeping hole (true? Or making SOME money off my warrantied item?  ???) so since they're right there...replaced it.  I'll report back on what that cost me when I get the bill...didn't have one ready when I got there.  Maybe in a year and a half when it goes again, I'll have them drill out the oil ports. Then it'll be fixed! (sure it will...)
Offline BWII
  • Carma: +188/-376
« Reply #12803 on: June 17, 2020, 01:58:31 am »
Forgot to mention...found some other things out about the Fusion.  It does have lane assist, but I don't know that it's a good one.  You get a warning chime if your hands aren't on the wheel.  It doesn't seem to recognize yellow lines. It pushed back when crossing the divided center, but kept right on going over the shoulder line which is solid yellow.  It did offer me a cup of coffee at one point...but I couldn't find the dispenser, and I don't drink coffee.  So no biggie.  I think it thought I was tired...I'm just testing you out girl!  Just testing you out!
When you hit the + button on the CC it picks up 2 kmh...if you click click click it it jumps up faster...if you hold it in...it jumps up by 10 kmh increments and then all of a sudden you're going 160 and it's still climbing...WTF!?  I only wanted to go from 100 to 110, so I held it in for what I thought would get me there, like mine does...and it just kept going so I let it...then I stopped letting it and figured out what it does...weird thing to have it do really.
The CVT seems pretty unintrusive.  It wasn't bothersome by any means.
The engine is buzzy as all hell up high(er).
It's hard to keep it in electric mode even at slow speeds.
I passed someone and it's not lacking for passing power.
Sport mode is better than Eco, but then you get no Eco out of it so what's the point?  Then buy the turbo model.
I was driving a little harder and faster on the way to town and still averaged about 5.9l/100 but my braking percentage was down from 92% to 86%...not very regenerative of me I guess.
It corners nice...I think maybe I need new socks and struts...but I've spent enough on mine this year.  Gotta get my cost average down so I'll wait...
Have I mentioned the seats are facking short? Fack are they short.  If I married a girl 5'3" it'd be perfect....for her.
Still impressed by the l/100s...better than the Sonic, and it's a real car. With real options.  Lots of options.
But it's gone now...never to grace the driveway of my home again.  Sara-nora oh sweet hybrid Fusion!! Adi-ose! Toot sweet! And all that...
  • Carma: +308/-518
« Reply #12804 on: June 18, 2020, 06:32:32 pm »
Finally gave it a bath... first one of 2020.
Before & after pictures... doesn't look much different, lol!!
Offline Railton
  • Carma: +243/-156
« Reply #12805 on: June 18, 2020, 07:02:55 pm »
After a few years of neglect I figured it was time to wax the G. Had it over 10 years now.
Railton
Offline Jaeger
  • Carma: +707/-12390
« Reply #12806 on: June 18, 2020, 07:17:42 pm »
Railton
Man that is looking so nice for a 10 year old car.
  • Carma: +308/-518
« Reply #12807 on: June 18, 2020, 08:10:50 pm »
Railton
Looks great!!
Offline Bubba
  • Carma: +382/-442
    • My photo site
« Reply #12808 on: June 18, 2020, 08:57:40 pm »
Railton
Boss!
« Reply #12809 on: June 18, 2020, 09:51:09 pm »
Dang, that cleaned up really well.
Offline Scaerio
  • Carma: +193/-127
« Reply #12810 on: June 18, 2020, 10:25:59 pm »
Great looking car!
Offline Railton
  • Carma: +243/-156
« Reply #12811 on: June 18, 2020, 10:57:26 pm »
Thanks gents! :cheers:
Paul - Yeah, get something for Kate and then the new house.
Toys come later. I'm due.
Railton
Offline dkaz
  • Carma: +289/-389
  • Flip flop
  • Cars: 12 Mazda 5 GT 6MT
« Reply #12812 on: June 19, 2020, 12:09:36 am »
I’ll be the first to give your 924 some love. Looks good!
Like the G too.
  • Carma: +308/-518
« Reply #12813 on: June 19, 2020, 07:20:54 am »
Like the G too.
LOL, thanks buddy!! BTW - its a 944 ;)
Offline Hannibalsmith
  • Carma: +101/-137
« Reply #12814 on: June 19, 2020, 07:42:59 am »
Like the G too.
DKaz, no need to hit below the belt...:)
  • Carma: +308/-518
« Reply #12815 on: June 19, 2020, 08:28:25 am »
^ha, ha, ha!!
Took it to the course this morning.
  • Carma: +101/-137
« Reply #12816 on: June 19, 2020, 09:14:09 am »
^^ Nice! Hey, did you recently buy a hot tub?
  • Carma: +101/-137
« Reply #12817 on: June 19, 2020, 09:24:04 am »
Railton
Ok, because its Father's day soon and this is a car enabler site, you deserve the following feedback:
- You already have a beautiful house, in a beautiful neighborhood
- You have a perfect hand me down car
- Your kid is on a great path
So, where is the damn Porsche?
Offline 2JDM
  • Carma: +119/-141
  • Carma: +308/-518
« Reply #12819 on: June 19, 2020, 09:44:40 am »
 :rofl2:
https://globalnews.ca/news/7083283/porsche-driver-woodstock-hot-tub/
Ha, ha, ha!!! That's a 968 [emoji14]
