Got the other 2 tires at work. Now they are ready to go on the nice black rims and finally give Kira the Lexus some traction, because apparently driving a sport sedan as intended is a bit much for the rears on the Toyo GSi5s...
While the tires get installed I am also doing a brake service, diff oil change, changing out both leaking axles, and putting in new coolant and brake fluid. Should do it for the spring! Might also think about doing an ignition system refresh, the car sometkmes does tend to crank for a while and be slow to fire up...
![](https://uploads.tapatalk-cdn.com/20200313/508bdbc6a166456b4270fd150dc851eb.jpg)
Sent from my SM-G935W8 using Tapatalk
