Warming up here from the -30's to -17 so did some vehicle work
Replaced the oil filter on the CRV, which fixed that leak. Not sure what the issue was exactly, seemed tight, but maybe not quite tight enough for -30's. Was a Wix XP filter, which has a good rep. Changed it for a Fram Ultra
Trekked out to the Vibe and tried boosting it again, and it fired up right away so could bring it home
Other than the weather warming up some, the only thing I had done was put a can of gas line antifreeze in the tank after it quit.
I'd thought gas line antifreeze was redundant with todays ethanol gasoline, but maybe not:
Q: Isn't using a gas line antifreeze these days ridiculous? All our "oxygenated" gasolines are at least 10 percent alcohol already.
What possible good would adding an additional 12 ounces of alcohol do? I think all the manufacturers and dealers of these products should be exposed for cheating motorists out of good money for a product with no value.
A: Ah, don't you just love a good conspiracy? You have a point that drivers today have little need for gas-line antifreeze additives, but I don't agree that these additives have "no value."
Technically, there is a significant difference between the alcohol in gas line antifreeze/de-icer and the alcohol in our gasoline.
Most fuel line additives are based on isopropyl alcohol -- stay away from any methanol-based de-icers, they can corrode fuel system components -- while our gasoline contains ethyl alcohol.
Isopropyl alcohol will combine with water and remix any phase-separated water/ethanol to accomplish two things: First, it will prevent water from freezing anywhere in the fuel system; and second, it will carry the "mix" through the system into the engine to burn. This prevents the moisture and alcohol from sitting in the bottom of the fuel tank waiting to leave you stranded by the side of the road.
You are correct that the ethanol in our fuel will mix with water and thus function as a gas line de-icer, but any significant percentage of moisture in the gasoline can cause phase separation because the ethanol would rather bond with water than with gas. I see some benefit in adding a single small bottle of isopropyl at the beginning of the cold weather to carry any existing moisture through the system, but continuously adding these products with each tank of fuel can result in too much total alcohol in the gasoline.
http://www.startribune.com/fuel-line-antifreeze-not-all-hype/36707014/
