Author Topic: Volt 2012  (Read 7934 times)
Offline me_2
  • Carma: +300/-76
Volt 2012
« on: June 24, 2012, 02:26:01 pm »
My new Chevrolet Volt 2012
Torque driven & electric regen goes so well together  ;D
Offline RunsinLight
  • Carma: +12/-34
  • Cars: 2018 Ford F150 XLT
Re: Volt 2012
« Reply #1 on: June 24, 2012, 02:42:05 pm »
My biggest concern about plugin cars is not having a garage. I'd be worried that someone would come along and steal the charging cable. Or does it lock in somehow?
Offline Guy
  • Carma: +481/-1215
Re: Volt 2012
« Reply #2 on: June 24, 2012, 02:44:02 pm »
Congratulations! Keep us informed on how you like the car!  :thumbup: :thumbup:
Offline me_2
  • Carma: +300/-76
Re: Volt 2012
« Reply #3 on: June 24, 2012, 02:51:40 pm »
Unfortunately, the 120Vac EVSE supplied with the Volt does not have lock capability at the J1772 connector (some others have) but you can: 1) Activate the alarm (honk) if unplug while charging 2) You can use cable + lock on the EVSE handle if you want to.
The electric charger 3,3Kw (120,208 or 240Vac input) itself is in the car, in the front right fender iirc. The EVSE is just a fancy cable, ground fault detector, contractor and communication module.
Offline me_2
  • Carma: +300/-76
Re: Volt 2012
« Reply #4 on: June 24, 2012, 03:11:03 pm »
I will. I did not change a car for another, I changed of century  8)
One of the most simple and effective anti theft 120Vac ESVE I have seen yet: The guy put the front wheel weight on the cable but using a rubber cable pass thru protector:
http://gm-volt.com/forum/showthread.php?7958-Portable-110V-cord-anti-theft-device&p=100408#post100408 unless a real motived one wants to cut the cord...
« Last Edit: June 24, 2012, 03:13:38 pm by me_2 »
Re: Volt 2012
« Reply #5 on: June 24, 2012, 04:41:59 pm »
Very nice!
  • Carma: +471/-416
Re: Volt 2012
« Reply #6 on: June 24, 2012, 05:36:16 pm »
Felicitations.....now give me back my 0.02cents in rebates...... ;D ..volte face....Latin fer aboot face........... ;)
Re: Volt 2012
« Reply #7 on: June 24, 2012, 07:10:01 pm »
Will the Volt "start" or whatever it does to get going with the charge cord attached?
Offline Sir Osis of Liver
  • Carma: +1376/-1726
  • Ramblin' man
Re: Volt 2012
« Reply #8 on: June 24, 2012, 07:16:46 pm »
Congratulations! Very nice!  :cheers: :thumbup:
H. L. Mencken
Offline normancw
  • Carma: +125/-132
Re: Volt 2012
« Reply #9 on: June 24, 2012, 08:20:43 pm »
Congrats - very cool.  I've only seen one on the road.  You might be the first on this site with a Volt!
― rrocket
Offline me_2
  • Carma: +300/-76
Re: Volt 2012
« Reply #10 on: June 24, 2012, 08:34:02 pm »
Technically, the Volt can "run" if the start button is depressed once (in the same time having the brake pedal pressed) when plugged BUT in won't move at all. So, you can have (electric compressor) A/C running while you're programming all your 36 preffered preset radio...
« Last Edit: June 24, 2012, 08:36:01 pm by me_2 »
Offline me_2
  • Carma: +300/-76
Re: Volt 2012
« Reply #11 on: June 24, 2012, 08:43:55 pm »
Thanks to all for the congrats,
Still about 700 (non-fleet) Volts delivered to Canada yet http://www.goodcarbadcar.net/2011/01/chevrolet-volt-sales-figures.html so it still rare to see another one except at my job, just across the street, there is a silver one parked in front of the office.
I posted here  http://www.autos.ca/forum/index.php/topic,79472.msg800390.html#msg800390 earlier today about the  Volt as commuter car
« Last Edit: June 24, 2012, 08:52:25 pm by me_2 »
Offline dr_spock
  • Spock
  • Carma: +46/-56
Re: Volt 2012
« Reply #12 on: June 24, 2012, 08:59:05 pm »
Congrats.    Happy with HydroQuebec?
Offline me_2
  • Carma: +300/-76
Re: Volt 2012
« Reply #13 on: June 24, 2012, 09:35:19 pm »
Well, I budgeted the worst case scenario to be $50/month but it was before we agree to let me plug at work, so it'll be half of that.
I still have to select, buy and get installed by a qualified electrician (some subvention available) a 240Vac EVSE at home: shorter charge time, pre-condition (heat or cool) the battery pack and cabin too ! Do not know yet if I will buy a 208Vac EVSE unit at work cause installation fee may exceed the advantage ...
H-Q. http://www.hydroquebec.com/transportation-electrification/charging-cost.html
2012 is a transition year: They started rolling out R-F "smart meter" but no TOU plan disclosed at that time
Actual rate http://www.hydroquebec.com/residential/tarif-residentiel.html If you use the higher residential  7,5¢/Kw.h + 15% taxes, it still below 9¢/Kw.h for now.
June 2012, without strong A/C use @15-25C, my 36Km one way trip to the office uses about 5Kw.h (half available form the battery), it cost approx. 50¢ if you add the efficiency losses @ 120Vac charge.
« Last Edit: June 24, 2012, 09:56:46 pm by me_2 »
Offline me_2
  • Carma: +300/-76
Re: Volt 2012
« Reply #14 on: June 24, 2012, 10:21:40 pm »
Few more pictures
ps: I edit my signature today and it no longer show up at the bottom of my post anymore, not idea why it disappeared ...?
« Last Edit: June 24, 2012, 11:43:25 pm by me_2 »
  • Carma: +70/-42
Re: Volt 2012
« Reply #15 on: June 25, 2012, 08:03:09 am »
Congrats on the new Volt.  Rock on.
Offline 5 Wheel Drive
  • Carma: +88/-20
Re: Volt 2012
« Reply #16 on: June 25, 2012, 11:19:44 am »
Nice.  I haven't seen too many around here.   :cheers:
Offline Snowman
  • Carma: +702/-1347
Re: Volt 2012
« Reply #17 on: June 25, 2012, 09:25:51 pm »
Nice wattage. After driving the Leaf Ii would like to try a Volt.
Offline me_2
  • Carma: +300/-76
Re: Volt 2012
« Reply #18 on: June 25, 2012, 10:21:49 pm »
Be careful, you could fall in love  :rofl:
Chevy Volt Powertrain Deep Dive (animation)
http://www.youtube.com/watch?v=IWSK8BR6LT8
or
its simplified version http://www.youtube.com/watch?v=80E1fOp95rA
Behind the wheel, you have to forget almost all you know about old car: lack of noise & vibration (I mean total silence idling in stop & go traffic, you come more "zen" at work than ever!  ;)), you have to re-learn how to drive, electric regen capture is fun, one pedal control is a possibility/reality. Using the fake "low gear" , it even able to keep its set speed on cruise control driving down a large mountain hill, weird feeling, don't have to touch the brake, recapture otherwise lost kinetic energy.
First week brings some tremendous smiles while a torque driven car pull you from a cold stop. Strange/mixed feeling, econo/expensive sporty but frugal car... I did not change car, I changed of century...
« Last Edit: June 25, 2012, 10:45:57 pm by me_2 »
Offline Triple Bob
  • Carma: +308/-574
  • Profesional Dash Stroker
Re: Volt 2012
« Reply #19 on: June 25, 2012, 10:22:55 pm »
Nice!
