Author Topic: CD Article: 2010 Audi S4  (Read 26677 times)
Offline Flinter
  • Carma: +44/-30
  • Cars: 2011 BMW 128i, 2017 Kia RIO EX, 2014 Toyota Tacoma 4WDGMC Sierra
Re: CD Article: 2010 Audi S4
« Reply #60 on: October 05, 2009, 07:51:04 pm »
Here is Edmunds review on the new S4.
http://www.edmunds.com/insideline/do/Drives/FullTests/articleId=158446
What Works:
Responsive and powerful engine; all-wheel-drive confidence; roomy backseat.
What Needs Work:
Lacks the feedback of its competition, but does it matter?
Bottom Line:
Quick, handles well, immensely fun to drive. Raises the bar in its segment in many areas, including price.
vdk
« Reply #61 on: October 05, 2009, 11:58:48 pm »
Apparently the V6 S/C is even better than BMW's TT.  :thumbup: :thumbup: :thumbup:
Offline Flinter
  • Carma: +44/-30
« Reply #62 on: October 06, 2009, 12:01:36 am »
Agreed, sounds very promising indeed. :)
  • Carma: +1254/-7210
« Reply #63 on: October 06, 2009, 12:04:06 am »
Wonder if they have a "no-tamper" fitting on the supercharger pulley so you can't up the boost with a pulley swap?
vdk
« Reply #64 on: October 06, 2009, 12:05:56 am »
IDK but you can up the boost with a flash...
« Reply #65 on: October 06, 2009, 12:24:43 am »
"If you thought Audi’s 2010 S4 was fast as it is, you’re in for a treat — The guys over at MTM have worked their magic and were able to up the car’s ante by a full 97HP with nothing more than an updated ECU and underdrive pulley.
This means an Audi S4 with the ~$3,500 MTM tuning kit will be able to produce a full 430HP, 380 pounds of torque and sprint from 0 – 60MPH in just 4.6 seconds. Any takers?"
Offline Flinter
  • Carma: +44/-30
« Reply #66 on: October 06, 2009, 12:26:18 am »
I'm certainly no expert here but I didn't think there was a simple ECU/Electronic way to control boost pressure with a roots type blower like the one used on the S4. I thought the boost pressure produced is purely a function of the RPM of pulley on the supercharger as well as the efficiency of the supercharger itself at a given RPM. You can however dial up the boost using a different pulley ratios as rrocket alluded to.
In a turbocharger, boost control this is accomplished using waste gates to bypass the exhaust turbine which therefore slows the compressor turbine reducing boost. The ECU controls this wastegate and therefore can easily control boost. Of course size and efficiency of the exhaust and compressor turbines and the housings also come into play as well.
Is my basic understanding correct??
Offline Flinter
  • Carma: +44/-30
« Reply #67 on: October 06, 2009, 12:28:34 am »
I'll buy the kit if you supply the S4.  ;D
Mitlov
« Reply #68 on: October 06, 2009, 12:31:07 am »
Who gets to keep the finished product?
« Reply #69 on: October 06, 2009, 12:36:01 am »
I do.  I'll give it a good winter road power-drifting test of the mods and AWD.
« Reply #70 on: October 06, 2009, 12:36:48 am »
You are correct.  A supercharger doesn't use a wastegate...which is what the boost controller (or ECU reflash) manipulates to make more boost.  In the case of a supercharger, you need the pulley to make more boost, but also the ECU re-flash to remap the fuel/ignition curves to take into account the extra boost.
Offline Flinter
  • Carma: +44/-30
« Reply #71 on: October 06, 2009, 12:46:05 am »
More air more fuel...that makes sense. Thanks.
Offline Flinter
  • Carma: +44/-30
« Reply #72 on: October 06, 2009, 12:47:20 am »
I forgot about that important detail. ;)
vdk
« Reply #73 on: October 06, 2009, 01:53:49 am »
OOpsie. Damn blowers...  :bang:
Mitlov
« Reply #74 on: October 13, 2009, 11:50:16 pm »
Got my new C&D today.  S4 beats the BMW 335i in a comparo.
Audi trumps it in real world handling, acceleration, grip.  They said the BMW is "aging and ready for a reboot".
Oh noez BMW!  They never lose C&D tests.  Hell, just six months ago, C&D declared a steel-wheeled, automatic-transmissioned 323i a winner in a comparison test with Thor's lightning-catapulting schlong.  What happened?!
In all seriousness, it seems that C&D's test wasn't a total anomaly.
Inside Line: S4 beats 335i
Their main criticism of the S4 was a higher as-tested price (US$59,000 versus US$49,000).  However, the tested models weren't equally equipped (the tested Bimmer needed the following to be similarly equipped to the tested Audi: a $2,000 AWD system, a $2,100 nav system, and a $875 premium audio system), so the actual price gap for similarly-equipped cars is $5,000, not $10,000.
On the other hand, they liked the Audi's engine better, found the Audi more confidence-inspiring in spirited driving on the street, thought that the Audi's suspension was better than the Bimmer's (there's a first), and found the Audi's back seat much more accommodating.
Nice showing Audi!   :skid:
« Last Edit: October 13, 2009, 11:52:58 pm by Mitlov »
« Reply #75 on: October 13, 2009, 11:58:48 pm »
^^Yea..and in another mag this month, the Audi TTS beats the 300HP 1 Series by a wide margin...
Offline Flinter
  • Carma: +44/-30
« Reply #76 on: October 14, 2009, 07:46:48 pm »
I was surprised in the Inside Line comparison test to see the S4 come out on top in the ratings for the Engine, Handling, Fun to Drive categories. All areas where BMW has been traditionally dominant.
Well done Audi!!
Offline 2JDM
  • Carma: +119/-141
« Reply #77 on: October 14, 2009, 10:09:50 pm »
But which one has better interior plastics? and better trunk space?  ;D ;)
Mitlov
« Reply #78 on: October 15, 2009, 03:30:44 am »
2hondas: 1.  CTC: 0.
Offline ovr50
  • Carma: +27/-126
« Reply #79 on: October 15, 2009, 10:18:50 am »
It's musical chairs at the auto mags time which means that as the Audi is new, and the 335i is not, it's Audi's turn to win. Then, in 2011 MY, when the 3 is renewed, it will it's turn to win. The beat goes on. Cynical? You bet. The car mags are fun, but hardly to be taken too seriously. Who are their largest advertisers? Car and car-related cos, so treat everyone somewhat fairly to keep the revenue flowing.
Audi has produced some seriously good vehicles lately, and they are to be congratulated for that. I'm sure the new S4 is an excellant car and likely deserves to win over the 335 at "this point in time".
and
