Author Topic: Make your own 'energy-efficient' faucet aerators  (Read 1593 times)
Squishy
« on: May 30, 2009, 12:11:24 pm »
Union Gas set up a free kit for us that included some 1.25 GPM 'energy-efficient' aerators and shower heads.  I took one apart to see if I could retrofit this onto the rest of our faucets, and found that these new aerators had just one extra piece - a thin disc with a small hole to restrict water flow.
All you need are the tools to remove your current aerator (I used slip-joint pliers), a type '2' plastic bottle with a flat panel (I used a Sunny D bottle), strong scissors, a 3/32" drill bit, and Teflon tape.
First, I removed the standard 2.5 GPM aerator and took out the gasket.  Using that as a template, I cut out a plastic disc from the plastic bottle.  The pictures are pretty bad because I couldn't get the lighting conditions right.
^ That disc was a rough first attempt.  The jagged edges are fine, but make sure it will fit snugly into the aerator.
Using a 3/32" drill bit, drill a hole into the centre of the disc.  Slip the disc in behind where the gasket sits, and make sure that it is snug on at least two sides (try a loose disc...very loud whistling).
Reapply Teflon tape to the aerator, reinstall, and test the water flow.  I doubt the little disc presents any danger of putting BPA into the water, but if you want to be safe, don't put one on the faucets used for drinking water.
  • Carma: +471/-416
Re: Make your own 'energy-efficient' faucet aerators
« Reply #1 on: May 30, 2009, 12:35:44 pm »
 ::) FLOMAX will FIX dat...................ask yer PLUMBER.................that decrease in "sea-men" will mean more seals eh!!!!
Offline Allen
  • Carma: +123/-440
« Reply #2 on: June 01, 2009, 09:23:30 am »
mind boggling waste of time :banghead:
  • Carma: +244/-779
« Reply #3 on: June 01, 2009, 09:45:26 am »
At work last year they had some energy conserving push and installed these in all the showers.  About 2 days later the restricting discs had all been removed by us so we could actually shower.  The complaints finally reached management a few days later and they replaced all the shower heads again, even though they had already been "fixed". :rofl2:
Offline aquadorhj
  • Carma: +271/-265
« Reply #4 on: June 01, 2009, 10:30:31 am »
Thanks for sharing, Squishy.
I know exactly what you are talking about.  I lived with clogged/weak running shower head for a while to understand the frustration...
Conservation is all good and fine, but I don't think most of us are really ready to change our shower habits.  Maybe the next generation will all be used to weak/drizzling shower heads and faucets.
Squishy
« Reply #5 on: June 01, 2009, 12:04:23 pm »
Haha, I'm actually fine with the restricted shower flow...doesn't really bother me and should bring the biggest savings.  All I had to do was angle the shower head more upwards so the spray would end up where it used to.  Aside from that, I don't even notice that the flow is reduced.
What I am a bit annoyed with is the restricted flow of the kitchen faucet.  Filling pots with water now takes about 50% longer, and I guess I could do without the disc and just turn the faucet on halfway when I don't need the extra flow.  I can't break the habit of just slamming the faucet all the way on, though, so I may just enlarge the hole in the disc.
