Honda and Toyota would tell us that the only way to survive a recession is to abandon performance cars.Thankfully, Mazda disagrees.QuoteHIROSHIMA, Japan — Sources close to Mazda told Inside Line today that the next Mazda RX-7 is still in the works. Inside Line has also learned that a new Mazda RX-8 is also in the works and is expected to be called the Mazda RX-9.Mazda will not let the rotary engine die with the current RX-8, sources tell IL. The company is well along in development of its next-generation RX-7, fitted with a front midship-mounted 16X rotary engine. The engine will generate upward of 270 horsepower from a normally aspirated power unit, they say.The new twin-rotor engine will feature an 800cc x 2 configuration, up from the current 13B's 654cc x 2 format, while improving fuel economy by 20 percent.By building such an engine, Mazda is looking to clean up a rotary image that was fraught with poor economy and emissions and excessive oil use.The next RX-7's transmission is also all new. It's a twin-clutch, two-pedal six-speed unit with a twist that allows drivers to set the revs at which the clutches engage.Engineers are also reportedly working on weight issues. By developing a new chassis, they have been able to shed some 220 pounds, reducing the RX-7's curb weight to the 2,640-pound range, according to one source.http://www.edmunds.com/insideline/do/News/articleId=141987That last sentence was bolded especially for Dorin. As for me, I'm stoked for the toddler-friendly RX-9.
Yeah like the 4 cyl Toyota banger is holding back LOTUS.......
