HIROSHIMA, Japan — Sources close to Mazda told Inside Line today that the next Mazda RX-7 is still in the works. Inside Line has also learned that a new Mazda RX-8 is also in the works and is expected to be called the Mazda RX-9.Mazda will not let the rotary engine die with the current RX-8, sources tell IL. The company is well along in development of its next-generation RX-7, fitted with a front midship-mounted 16X rotary engine. The engine will generate upward of 270 horsepower from a normally aspirated power unit, they say.The new twin-rotor engine will feature an 800cc x 2 configuration, up from the current 13B's 654cc x 2 format, while improving fuel economy by 20 percent.By building such an engine, Mazda is looking to clean up a rotary image that was fraught with poor economy and emissions and excessive oil use.The next RX-7's transmission is also all new. It's a twin-clutch, two-pedal six-speed unit with a twist that allows drivers to set the revs at which the clutches engage.Engineers are also reportedly working on weight issues. By developing a new chassis, they have been able to shed some 220 pounds, reducing the RX-7's curb weight to the 2,640-pound range, according to one source.
The engine will generate upward of 270 horsepower from a normally aspirated power unit, they say............while improving fuel economy by 20 percent.
QuoteThe engine will generate upward of 270 horsepower from a normally aspirated power unit, they say............while improving fuel economy by 20 percent.So about 25% more hp and 20% better economy. I'll believe it when I see it.
They should offer the RX-8 or newer variants with the rotary or the MS3 engine, and see which one sells best.
Here we go: Lexus IS, one generational change (IS300 AT to IS350): 42% increase in horsepower AND an 11% increase in combined fuel economy (according to 2008+ EPA ratings system). So it can be done.
Quote from: Mitlov on February 14, 2009, 06:02:23 pmHere we go: Lexus IS, one generational change (IS300 AT to IS350): 42% increase in horsepower AND an 11% increase in combined fuel economy (according to 2008+ EPA ratings system). So it can be done.The IS300 had an I6 and the IS350 is a V6....two totally different engines.
Honda and Toyota would tell us that the only way to survive a recession is to abandon performance cars.Thankfully, Mazda disagrees.
As for me, I'm stoked for the toddler-friendly RX-9.
Quote from: Just Bob on February 14, 2009, 09:48:43 amThey should offer the RX-8 or newer variants with the rotary or the MS3 engine, and see which one sells best. My understanding is that this is a physical impossibility, because the RX-8 is designed around the idea of a tiny, superlight rotary engine. From what I've heard, there's no room for a turbo four under the hood, and and a turbo four would dramatically alter the weight balance.
My RX-8 is super toddler friendly Mitlov...and it doesn't seem to burn a lot of oil either.
