Author Topic: Suzuki sidekick transmission  (Read 1548 times)
Fixer0330
« on: June 10, 2008, 07:48:37 pm »
I changed the transmission in my 97 sidekick and can not get the clutch pedal off the floor. It goes down easy but does not return and seems to be ingadged all the time I have had transmission out sevral times and just put a whole new clutch kit in the last time and it is the same. Does anyone know what I'm missing as next I'll pull it again and check that the throw out bearing is not stuck again but Im sure Im doing somthing wrong
Wolfe
Re: Suzuki sidekick transmission
« Reply #1 on: June 10, 2008, 08:29:13 pm »
Sounds like a problem with the master or the slave cylinder. You bled the system right?
barrie1
« Reply #2 on: June 10, 2008, 11:24:39 pm »
Fixer0330 Welcome to the Forum and yes I agree with Wofe on this. Definitely check the cylinder for fluid and that its hooked up correctly as well.  :)
