Author Topic: 3.7L for G sedan and EX  (Read 3186 times)
Offline Iso Octane
  • Carma: +0/-3
  • to the beat of the different drum
Re: 3.7L for G sedan and EX
« Reply #20 on: February 27, 2008, 12:26:03 am »
Is the Nissan V6 60deg or 90deg?    for proper balance V6s should be 60deg ( or 120 but that would not fit into most engine compartments)
I notice that the M-B V6 is 90 degrees... may make for cheaper tooling but one would hope that M-B would make a proper engine.
Are you sure?  At least with twin-cylinder engines, the opposite is true.  Ducati and Suzuki sport-twins have 90-degree Vs and are known for their perfect balance, whereas the Aprilia 60-degree V-twins require twin counter-balancer shafts.
Here's a detailed in-depth article about engine smoothness: http://www.autozine.org/technical_school/engine/smooth1.htm
Quote from: that link
For better balance, most V6s are arranged such that the banks are placed at either 60° or 90° to each other. In this way, the movement of cylinders in bank A matches those in bank B, thus there is no vibration generated between banks.
And it goes on about other engine configs and stuff.  Good reading.  8)
