Author Topic: Quick and simple question about the Honda Fit....Does it use a timing chain?  (Read 3245 times)
superbaldguy
I thought I read that, somewhere, seems unlikely a compact uses a chain as that seems to be a feature of a higher-end car, although my 2001 Sentra GXE uses one.......I couldn't really see that on the specs at Honda Canada, either.
Insights?
avtoller
The Yaris uses a chain, but if I recall correctly, the current generation Fit uses a belt.
superbaldguy
Yeah, I'd be surprised, too. Does the Versa use a chain?
Offline marineboy
  • Carma: +1/-1
From world.honda.com
"Refinement is further enhanced with electronic Drive-by-Wire throttle control, which provides quick throttle response, smooth automatic transmission shifts (on automatic transmission models) and precise fuel delivery to the engine. Friction reducing technologies include roller bearing tipped rocker arms, a low friction timing chain tensioner, molydebenum coated piston skirts and an offset crankshaft/connecting rod design."
From this one can infer that it has a timing chain. ;)
Offline mwqa
  • Carma: +10/-18
  • Cars: 2012 Suzuki SX4
I did a search over on Fitfreak.net and everyone is saying that the Fit has a timing chain.
For example:
http://www.fitfreak.net/forums/fit-talk/15752-timing-belt-scheduled-maintenance.html
avtoller
 :-[ :-[ :-[  Wrong as usual, I guess.  :-[ :-[ :-[ ;D
Offline Seafoam
  • Carma: +89/-202
I assumed it was a belt as well.Most hondas in the past used a timing belt. That's good ,one less maintenance item to deal with.
2023 Honda Civic EX-B
2004 Mazdaspeed Miata
2016 Toyota Tacoma SR
Offline Schmengie
  • Carma: +27/-26
Yes, the Versa uses a chain. Quite a refined and quiet little motor IMO.
superbaldguy
Thanks, guys. My next new car will be either the Fit or the Versa.
avtoller
Excellent choices, both.  :thumbup: :thumbup:
  • Carma: +471/-416
when ya PULL the chain does the OIL FLUSH............ :-*........now there's a HANDY THO'T...... ;)..........
The workshop manual shows a chain. Complete with several references to NOT let the chain anywhere near a magnetic field...from which I guess one can assume that it is a steel chain.
  • Carma: +471/-416
 ::) better not go to SEDONA then tpl.... :P
