Author Topic: Manufacturer recommended torque setting for Winter Steel Rims  (Read 2216 times)
canadianexpress
« on: October 24, 2005, 01:20:37 pm »
Just wondering if Winter Steel Rims should be torqued to the same settings as the Alloy.
Thanks
Offline footlong58
  • Carma: +12/-3
  • Cars: 2007 Toyota Yaris, 2014 Chevrolet Trax, 2008 Buell, 2005 Yamaha V Star
Re: Manufacturer recommended torque setting for Winter Steel Rims
« Reply #1 on: October 24, 2005, 04:44:31 pm »
I believe most should be torqued to 90 lb/ft , give or take...
  • Carma: +310/-6813
« Reply #2 on: October 25, 2005, 12:34:47 am »
90 lbs is what I use as well.
« Reply #3 on: October 25, 2005, 06:45:43 am »
You need to know if the nuts have the same profile for the steel wheels as for the Alloys. There are two different profiles....its mentioned in a thread over the last month in this forum section
 If the wheels either, came from the car dealer or from tiretrend ( who supply correct nuts you'll be ok.
morty
« Reply #4 on: October 26, 2005, 01:42:52 am »
Just use the factory specs for torque...
