Author Topic: Help with installing Asymmetrical tires  (Read 2200 times)
phathomatik
« on: October 23, 2005, 09:42:51 pm »
I just bought a set of Pirelli Wintersport 210 tires already installed on a set of steelies.  They are all installed with the same side outwards.  (Each side has a different side wall)
I was under the assumption that these tires were also directional and should be installed a certain way.  (Two with one sidewall outwards, and two with the other side outwards)  Could someone (Morty  :) ) tell me how these tires should be installed.
Thanks.
mdxtasy
Re: Help with installing Asymmetrical tires
« Reply #1 on: October 23, 2005, 11:09:36 pm »
Check the arrow on the sidewall...they should point towards the way they should be rotating.
morty
« Reply #2 on: October 24, 2005, 12:27:23 am »
There is no arrow on assymmetrical tires. They are designed with an outside tread and an inside. All 4 tires should be installed the same with the sidewall labelled "Outside" facing out. These tires are not directional. They can be rotated and mounted to any position on the vehicle. Nice and easy!
mdxtasy
« Reply #3 on: October 24, 2005, 01:05:24 am »
Damn....mis-intrepreted the message.  But I guess reading the sidewall would do it?
Offline capriracer
  • Carma: +19/-2
    • www.barrystiretech.com
« Reply #4 on: October 24, 2005, 06:34:43 am »
If the tires are asymmetrical, there should be something on the sidewall that says "This Side Out".
If they are directional, they will have the arrow.  If they are both asymmerical and directional, they'll have both.
Sounds like you have asymmetrical and they have been installed correctly.
CapriRacer
msian
« Reply #5 on: October 24, 2005, 09:05:48 am »
I too had the Pirelli Snowsport 210. They are definitely not directional...just asymmetrical.
It is kinda difficult to visualize the asymmetricity (is there such a word? :P) of the Pirelli 210 as the tread pattern is not very drastic.
If you look at the Yokohama Parada, then it is more apparent.
phathomatik
« Reply #6 on: October 24, 2005, 07:26:18 pm »
Thanks for all the help everyone.
  • Carma: +471/-416
« Reply #7 on: October 25, 2005, 12:04:54 am »
..can you tell me the Directions to the A Cemetry............. ::)
citydude
« Reply #8 on: October 26, 2005, 12:40:16 pm »
Are all assymmetrical tires not directional, or just the Pirelli ?
Citydude
msian
« Reply #9 on: October 26, 2005, 01:25:39 pm »
I believe the BFGoodrich g-Force KD is both asymmetrical and directional.
IIRC so was the older Goodyear GS-C and the older Pirelli PZero (the newer ones are separated).
