The calc is absolute, but manufacturers all have different specs, so you might be a little lower or higher depending what you choose. IMO I would go with the stock size as there is lots of selection and then you are guaranteed to not have any ABS or rubbing issues. If you want you can run a 185/65/15 to get a little narrower track and there are quite a few options in this size as well.
