Author Topic: Another tire size question 195/75/14 to 195/70/14  (Read 4453 times)
bowser
« on: September 30, 2005, 04:41:01 pm »
Looking at the Nokian WR's.
My current size is 195/75/14 (producing an overall diameter of 25.52")
The closest size (I think - unless someone can point me to another size) they have to this are the 195/70/14's (diameter of 24.75").  The difference is a little over 3/4 of an inch (.77") smaller producing an acutal speed of 97km/hr at a speedo reading of 100km/hr (or 126km/hr at a reading of 130km/hr).
Is it ok to go with these? (namely if I dont care about the speedo reading discrepency what other issues/problems will I have if I go to these tires for example will they physically fit on my original rims, etc)
Many Thanks
Offline Minou
  • Carma: +11/-26
  • Cars: 2018 Mazda 3 GS, 2016 Ford Edge SEL, 2016 Suzuki Burgman 650 Executive
Re: Another tire size question 195/75/14 to 195/70/14
« Reply #1 on: September 30, 2005, 09:19:05 pm »
I would get 205/70-14 if available.
Difference in diameter would be a fraction from stock.
bowser
« Reply #2 on: September 30, 2005, 10:30:05 pm »
I believe the largest 14" they have is the 195/70/14
I didnt notice any 205's in a 14"
morty
« Reply #3 on: October 01, 2005, 02:08:00 pm »
What type of vehicle...year, make, model?
bowser
« Reply #4 on: October 02, 2005, 10:59:55 am »
Its for a 1996 Oldsmobile Ciera SL
morty
« Reply #5 on: October 02, 2005, 05:10:52 pm »
You are fine with the 195/70R14 on your Ciera. The car appears to have come with 185/75/14 originally, so the 195/70R14 is actually the perfect subsitute. Very close to the original stock overall diameter.
bowser
« Reply #6 on: October 13, 2005, 11:59:49 am »
Thanks for the reply
However, there were two tire sizes used on that car in 1996.  I think if you got the aluminium rims the size of tire was 195/75/14 with steel wheels it would have been as you said.
So the question still remains, will be ok to go with the different sized tires (difference in diamter of 3/4")?  The only problems I will have is the speedo discrepency correct?
Thanks
Offline davidy
  • Carma: +2/-3
« Reply #7 on: October 13, 2005, 09:17:45 pm »
Thanks
A rule of thumb is plus or minus 3% for the overall tire diameter. 3/4"/25.5" is about 3%.
Dave
2010 Ford Ranger FX4
Armaguard spray on liner
morty
« Reply #8 on: October 14, 2005, 01:07:13 am »
Ideally you should go with the OE 195/75/14. However, if the tire you must have only comes in the 195/70/14, you should be fine. It is a small difference, but in this case I think it is within or close to the spec.
