Author Topic: Winter tire pressure  (Read 2448 times)
canadianexpress
« on: September 29, 2005, 06:53:20 pm »
Some manufacturer recommends adding 3 psi to the recommended one for winter tires.  Does anymore know the reason for this.
Thanks in Advance.
morty
Re: Winter tire pressure
« Reply #1 on: September 29, 2005, 11:52:31 pm »
When temperature drops, so does the air pressure. When you are in the midst of a cold snap check the air pressure in the morning before you begin to drive. You will find the tires a little lower than normal. Bump your pressure to the one listed on the driver's door placard or owner's manual. Remember to check your pressure once a month or when there is an extreme weather change.
canadianexpress
« Reply #2 on: September 30, 2005, 09:28:17 am »
Thanks for your reply.
« Reply #3 on: September 30, 2005, 12:05:03 pm »
In general ( I am sure there are exceptions) I think they reccomend an extra few pounds due to most winter tires being 1 speed rating lower than the summer tires. The exra pressure helps compensate for the softer sidewalls of the winter rubber.
