I am hoping someone can answer a few questions I have on rim size. My current car has 16" rims with a 5X114.3mm bolt pattern and a 64.1mm hub. The offset is 55mm.
I'm looking at a car that also has 16" rims with the same bolt pattern, but the offset is only 45mm.
Would I have any problems using my existing rims on the car with the smaller offset?
From what I understand, offset is the distance the wheel centre sits from the hub. Is this correct? What is the effect of using the wrong offset?
Also my current car uses 205/60R16 sized tires while the car I'm looking at comes with 205/55R16 tires. This is a 3.2% difference in diameter which is just over the recommended 3% limit. When combined with the difference in offset can this cause additional problems?
