Author Topic: Dent's crazy custom project - 1952 Austin A40 Somerset 'Special'  (Read 16070 times)
Offline Serniter
  • Carma: +40/-20
  • Cars: 2017 Lexus ES350
Re: Dent's crazy custom project - 1952 Austin A40 Somerset 'Special'
« Reply #80 on: October 07, 2022, 12:13:04 am »
Thank you for the update. This is going to look great when done. Did you decide on a colour yet?
Online Gurgie
  • Carma: +309/-518
« Reply #81 on: October 07, 2022, 07:25:32 am »
I think I'd like to just sit in Dent''s garage and smoke a cigar and watch him work.....
:iagree:
Offline StivenJK
  • Cars: BMW F10, Mercedes C126
« Reply #82 on: October 11, 2022, 09:57:14 am »
I've always wanted to build a hot rod. But not your stereotypical '32 Ford. Something a little more unique, a little cheaper. A little more me. I like British cars, I like engine swaps. Maybe some semi-radical body work. So why not? We'll keep the budget super low in case it fails.
So I bought this back in 2021. Its an Austin A40 Somerset that has been sitting a long, long time. Maybe up to 60 years off the road. Likely any mechanical bits are toast which is fine as I'd like to modernize it a bit. The car had been for sale online for quite a long time. I'd been watching it but it was a good drive away and a little bit too much money. But out of the blue they lowered their price (moving, I found out later). So I bought it based off a handful of Kijiji photos.
It was a five or so hour drive to go collect it. Have you heard of Dog Pound, Alberta? Me neither but that is where we are going. Fun name though. We used my son's at the time high mileage Chevy pickup and a borrowed trailer (thanks Rod!) to collect it.
We got a bit lost and turned around thanks to Google Maps guessing when it does not know rural addresses. I really wish it would say "I don't know" rather than silently substituting something "close". We ended up about 40kms too far west before the owner got us sorted.
It has a 1.2L four cylinder (pre-B-series) engine with a four speed manual on the column. It received rear hydraulic brakes and a 2hp boost over the A40 Devon.
I think the original colour might have been the light green but the red showing through is primer. Amazingly good primer. A really solid shell so must have spend some time inside.
The seller let us know that the frame was no longer bolted to the body! He had planned to swap it onto a Suzuki Sidekick frame. The larger front suspension had stopped him before getting too far. The not attached to itself problem for loading problem was solved by his front end loader. I did not have one at the other end but that was a few hour from now problem.
Wow! This car must be very important to you! I tried to restore C126, but it just needed to paint the car and change the interior. But such a large-scale restoration... it commands respect, I hope you will be pleased with the result.
Offline Arthur Dent
  • Carma: +186/-80
  • 42?
« Reply #83 on: October 17, 2022, 11:43:57 pm »
I was able to buy two of these Austin A40 hubcaps. I still need two more but progress. These apparently came off a rare pickup.
The left wheel is a 16" Nissan Sentra wheel which I plan to use mocked up with the cap. I'll need create a mounting system. On the right is the stock A40 16" rim.
