Main specs revealed:
https://insideevs.com/news/544167/toyota-bz4x-specs/Toyota bZ4X specs (Japan):
Toyota bZ4X
FWD version:WLTP (WLTC): about 500 km (311 miles)
71.4 kWh battery
355 V, liquid cooled
battery capacity retention ratio (target): 90% after 10 years or 240,000 km (150,000 miles)
0-100 km/h (62 mph) in 8.4 seconds
top speed of 160 km/h (100 mph)
front-wheel drive (E-axle - integrated motor, single-speed transmission and inverter)
"AC synchronous" motor
peak system output of 150 kW and 265 Nm of torque
AC charging (on-board): 6.6 kW (three-phase 11 kW option for Europe)
DC fast charging: up to 150 kW (up to 80% in about 30 minutes)
Weight: 1,920 kg (2,195 kg total)
Dimensions: Length - 4,690 mm, Width - 1,860 mm, Height - 1,650 mm (antenna), Wheelbase - 2,850 mm
Heat pump-type air-conditioning
Over-the-air (OTA) software updates
e-TNGA platform
Toyota bZ4X
AWD version:WLTP (WLTC): about 460 km (286 miles)
71.4 kWh battery
0-100 km/h (62 mph) in 7.7 seconds
dual motor all-wheel drive (E-axle - integrated motor, single-speed transmission and inverter)
two 80 kW "AC synchronous" motors
peak system output of 160 kW and 336 Nm of torque
Weight: 2,005 kg (2,275 kg total)
e-TNGA platform
