Author Topic: Bob's New Vehicle  (Read 39940 times)
Online rrocket
  • Carma: +1254/-7214
Re: Bob's New Vehicle
« Reply #160 on: February 02, 2021, 04:38:10 pm »
But the suggestions above change the speed from 4% (275/70) to 10% (285/75) out. Doesn't that mess up speed, mileage, odometer etc.? It may have a lot of horsepower, but it's not a fast accelerating vehicle as is. Won't larger wheels make it slower to accelerate?
Also the guy that posted that pick said, "Got the truck cleaned up and on level ground. 2008 with 2” spacer, 275/70/18 Ridge Grapplers and 18x9 Method double standards, +25mm offset."
I'm thinking the 2" spacer is on the suspension, not the wheel. Could be wrong.
Every pic I've seen with larger wheels generally has a lift kit of some kind installed. I don't want it any higher.
Spacer is typically a wheel spacer.  When it's a lift, they usually say lift.
  • Carma: +269/-457
« Reply #161 on: February 02, 2021, 04:44:08 pm »
Oh ya, 285/75R18 is too big, and unless you're lifting the truck or adjusting the wheel spacing, will rub.
Check out the official 'largest tire you can run stock for all generations thread': https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/
On the 2nd and 3rd gen trucks with stock suspension, you can run a 275/60R20, which is one inch taller but same width as factory.  Let's compare a 275/60R20 to a 275/70R18.
275/60R20 has a diameter of 32.9" - one inch taller than factory
275/70R18 has a diameter of 33.1" - one inch taller than factory
I seriously doubt that .2" is going to make any difference, and you should be fine to run the 275/70R18's on your truck.
The way I see it, you have two options:  Stay with the stock 18" size, which is 275/65R18, or step up one size to 275/70R18.  Either way you can't really go wrong.
Some people put spacers on because they want to A) run a wider tire and don't want the tires rubbing the inner fender liner, or B) want the tire to stick out past the side of the truck.  I personally find the look where the tire sticks out past the side of the truck to be quite stupid, and I'm pretty sure it's also illegal.  It's not too bad if you're running some fender flares.  Then again, spacers are stupid, and you're adding in a point of failure on one of the most important interfaces on your truck (wheel to axle).
« Last Edit: February 02, 2021, 04:47:06 pm by Great_Big_Abyss »
Offline Triple Bob
  • Carma: +308/-574
  • Profesional Dash Stroker
« Reply #162 on: February 02, 2021, 05:29:12 pm »
Yeah I wouldn't use spacers, as the method wheels already have lower offset so will stick out a little bit more than OEM.
My biggest question on the 275/70 R18's is what that does to acceleration, handling etc. being 4% larger than OEM?
Offline dirtyjeffer
  • Carma: +296/-1312
« Reply #163 on: February 02, 2021, 05:49:21 pm »
it reduces it by 4%.  :P
  • Carma: +269/-457
« Reply #164 on: February 02, 2021, 06:14:26 pm »
I doubt you will notice a difference.  3% is nothing.
But if you're losing sleep over it, go with the 275/65R18.  That's also the right choice.
Offline Patrick_D1
  • Carma: +100/-104
  • Cars: 2024 GTI, 2024 Tiguan R-Line Black
« Reply #165 on: February 02, 2021, 09:48:55 pm »
Awesome choice, Bob!
Semi-related, after all this ID.4 talk, guess what's in my garage this week...  ;)
Manual gearbox evangelist. Die-hard automotive and motorsport enthusiast. Often found covered in mud.
« Reply #166 on: February 02, 2021, 10:09:00 pm »
Oh, you bastard  :D
Watcha think?!
« Reply #167 on: February 03, 2021, 08:37:51 am »
The larger tires will affect acceleration and braking, but only slightly.  And then you'll get used to it and not even notice.
I ran tires that had a 10% larger diameter on a 4cyl Ranger and it was fine.  I bet you won't even notice 3%-4% on the Tundra.
  • Carma: +244/-779
« Reply #168 on: February 03, 2021, 03:17:20 pm »
Spacers are no longer HTA compliant in Ontario anyhow
  • Carma: +269/-457
« Reply #169 on: February 03, 2021, 03:30:19 pm »
They've never been non-douchebag compliant, either.
Online rrocket
« Reply #170 on: February 03, 2021, 04:51:39 pm »
Easy there.   :rofl: :rofl2:
While I may or may not be a douchebag, I've run small spacers before on my cars.
Even made a custom set for the Supra.
Offline Arthur Dent
  • Carma: +186/-80
  • 42?
« Reply #171 on: February 03, 2021, 04:54:39 pm »
I ran spacers on my (origional) Micra so I could ditch the 12" rims. Not the usual douchebag magnet material.  :rofl2:
« Reply #172 on: February 03, 2021, 04:57:28 pm »
Yeah, but did you space your muffler?  ;D Ya gotta space your muffler to qualify nowadays  :rofl2:
  • Carma: +269/-457
« Reply #173 on: February 03, 2021, 04:59:37 pm »
I was talking more with regards to trucks.
This is a ridiculous look:
Offline dirtyjeffer
  • Carma: +296/-1312
« Reply #174 on: February 03, 2021, 05:20:50 pm »
i realize that is in Virginia, but i think it is illegal to have your wheels stick out beyond the fenders here.
  • Carma: +269/-457
« Reply #175 on: February 03, 2021, 05:37:21 pm »
It is.  Still doesn't stop some people around here.  The redneck factor is strong in the prairie provinces.
  • Carma: +391/-634
« Reply #176 on: February 03, 2021, 11:06:54 pm »
I've lost track of the number of pickups like that around here.
Offline Blueprint
  • Carma: +170/-233
  • member since way back when
« Reply #177 on: February 04, 2021, 09:10:54 am »
Congrats on the truck! I prefer the stock alloys myself, looks classier and less "bro-ish". Some people think the bigger the better...
  • Carma: +1424/-2122
« Reply #178 on: February 04, 2021, 10:22:20 am »
I...I actually really like that. Its too bad that usually those are accompanied by 22" rims with low profile mud tires.
« Reply #179 on: February 04, 2021, 10:29:55 am »
I like the wheels you have now, really no reason to change them out
I would save the money for other tools
