Author Topic: Used Vehicle Review: Acura MDX, 2014-2018  (Read 3398 times)
Offline AutoTrader.ca
  • Carma: +14/-17
  • Cars: Car
« on: September 13, 2018, 08:25:48 am »
Solid choice.
Read more...
Offline EV-Light
  • Carma: +125/-1490
Re: Used Vehicle Review: Acura MDX, 2014-2018
« Reply #1 on: September 13, 2018, 03:17:15 pm »
What an awful list of issues for such a new vehicle!
  • Carma: +1424/-2122
« Reply #2 on: September 13, 2018, 03:19:08 pm »
So with the whole direct injection thing, would a few trips to redline a few times a week prevent the carbon buildup??
« Reply #3 on: September 13, 2018, 03:27:08 pm »
I don't think so. With DI there is no fuel washing the back of the valves. Carbon buildup on the business side of the valves? I don't think that has been much of an issue since the advent of fuel injection. On my Land Rover (DI) I have shortened oil change intervals to 6-8k kms since I don't want dirty oil on the EGR coating the back side of the valves. So far so good.
« Reply #4 on: September 13, 2018, 03:35:32 pm »
We must have read a different article.  An alignment is an easy fix and the warped brakes could be user related.  Granted the 9 spd transmission seems suspect but that's avoided by buying an older model.
All DI motors are plagued by carbon issues, so Acura is not alone there.  I've read using top tier gas can help minimize the buildup, not sure if that's true.
Offline lebowski
  • Carma: +96/-70
  • Cars: Car: '06 Legacy GT Wagon 5-speed. Rich corinthian leather upholstery. Roof rack. AM/FM/CD.
« Reply #5 on: September 13, 2018, 04:13:22 pm »
These really do seem like great rigs to buy used: most of the advantages of a Lexus RX350, but with lower resale value and greater driver engagement (for a midsize CUV at any rate).
« Reply #6 on: September 13, 2018, 04:17:32 pm »
I did not  find  the drivers seating area that comfortable, I went with the RX
« Reply #7 on: September 13, 2018, 05:19:00 pm »
The only solution to DI carbon build up is a service to have it removed.  There's no driving technique, etc that helps.  It's just a fact of not having fuel flow over the intake valves.  Modern fuels have amazing cleaning additives that are mostly wasted on DI engines.
If you don't want to have to deal with services required for DI engines, buy a non DI engine or a D4S engine from Toyota.  Even over at Toyota, the 2.5L six has "normal" DI (one of the few Toyota engines to have it) and it requires periodic carbon servicing.
I'd for sure try to avoid buying anything with the ZF 9-speed.
I prefer the RX to the MDX, but that's just a personal preference based on driving position, visibility, and individual things like that.  The Acura is a solid product and a good choice.
Offline lebowski
  • Carma: +96/-70
« Reply #8 on: September 13, 2018, 05:36:27 pm »
Ahh I see. That would be a key factor for me as well.
« Reply #9 on: September 13, 2018, 05:41:06 pm »
So DI was another one of those "improvements" thats caused way more problems than it solved....gotch.
Offline Railton
  • Carma: +243/-156
« Reply #10 on: September 13, 2018, 05:47:32 pm »
DI and timing belts - no thanks.
Railton
Offline dirtyjeffer
  • Carma: +296/-1312
« Reply #11 on: September 13, 2018, 06:10:51 pm »
i think using quality fuels and doing regular maintenance should go a long way...you shouldn't be getting any crap on the back side of the valves anyways.
« Reply #12 on: September 13, 2018, 06:13:57 pm »
What about EGR?
Offline dirtyjeffer
  • Carma: +296/-1312
« Reply #13 on: September 13, 2018, 06:32:27 pm »
What about EGR?
not every vehicle uses an EGR (the FCA Pentastar V6 for example)...also, if you are using the proper oil and top tier fuel, you're likely reducing the chance of having crap in the first place...Justin Pritchard wrote an article on it a couple of years ago:
http://thechronicleherald.ca/wheelsnews/1366531-dirty-valves-and-direct-injection
Offline EV-Light
  • Carma: +125/-1490
« Reply #14 on: September 13, 2018, 07:09:01 pm »
We read exactly the same article - a 4y old vehicle should have a list of very minor issues, not things like carbon issues, 9 speed woes, etc....
If we were talking 8-10y, I’d praise this as super reliable.
« Reply #15 on: September 13, 2018, 07:14:10 pm »
The worry with any Honda is the transmission.  They just had some on-again/off-again issues and I'd do my homework on specific models/years very carefully before buying a used Honda.  Get one with a solid trans, and you're getting a good used machine.
Offline lebowski
  • Carma: +96/-70
« Reply #16 on: September 13, 2018, 07:15:00 pm »
Just WRT direct injection: no expert but FWIW this was explained to me once by a Toyota / Lexus mechanic friend (i was looking at IS 250's and 350's at the time): the IS 250's 2.5L V6 motor is DI and no good because of carbon buildup issues. The 350's motor is DI as well, but way better, because it also had additional port fuel injection, which prevented carbon buildup.
« Reply #17 on: September 13, 2018, 07:23:19 pm »
The 3.5L V-6 comes in several configurations.  The AWD/RWD version as used in the IS350 uses Toyota's superb D4S injection system which uses both port and direct injection.  Port injection is better for certain rpm ranges and for engine cleaning, DI is better for some higher rpm zones, so Toyota builds a system that uses both.  You literally get the best of both systems.
D4S has been around for a while now and is proven.
Offline lebowski
  • Carma: +96/-70
« Reply #18 on: September 13, 2018, 07:28:55 pm »
Ahh gotcha. Yeah, that sounds like what he told me as well. Do any other mfr's use a version of this D4S technology? Seems everyone has had problems with carbon buildup except Toyota and that motor.
Offline bridgecity
  • Carma: +126/-182
  • Cars: 2014 MDX; 2007 Tundra
« Reply #19 on: September 13, 2018, 07:34:54 pm »
We've had our '14 since the spring of 16, so 2.5 yrs.  We had a couple of issues sorted shortly after buying including:
- clunky rear suspension; there's a TSB for it so it was updated.  Big improvement with the new parts.
- steering would make weird sound when backing out of driveway, turning wheel, and shifting into drive.  It was hard to duplicate but fixed with a reprogram.
- finish on passenger side door handles was failing/flaking/corroding.  Replaced under warranty.  Dealer said they had a bad batch of them, but only affected passenger side.  Weird.
Its been solid since those initial items.  My experience with Honda is that the above items would be addressed in later years.  The wife loves the thing and to be honest I really like it.  Great V6, awesome AWD.  Infotainment sucks compared to new cars but no biggie for me.  My phone links fine so its all good  ;D. We consistently get in the 8's (l/100km) cruising at 120 on the highway.  We've done several extended highway trips and I find the seats great.  mmret hates his so there's that, ha ha.
That said, I really like the look of the future Lincoln Aviator.  Will be on the list when its time to update the Acura, but no plans to sell anytime soon.
« Last Edit: September 13, 2018, 07:37:22 pm by bridgecity »
