Author Topic: 2016 M4 GTS boosts power with water injection  (Read 10389 times)
Offline RaHorakhty
  • Carma: +2/-7
  • Cars: Toyota Matrix
Re: 2016 M4 GTS boosts power with water injection
« Reply #20 on: October 21, 2015, 02:27:15 pm »
So do you have to fill 'er up with water? Is there a second fuel hole and tank? What if you live in an apartment and don't have access to an outdoor hose, do you have to carry a canister down to your car from your 45th floor apartment? Is it better if you use a Brita filter or  Poland Spring bottled water for best quality, maybe that distilled water stuff they sell at the baby supply stores is best?
  • Carma: +1424/-2122
« Reply #21 on: October 21, 2015, 02:29:57 pm »
I doubt anyone that owns a striped out race car lives in an apartment and keeps the car at home.......
Offline mixmanmash
  • Carma: +103/-326
« Reply #22 on: October 21, 2015, 02:39:50 pm »
You got it wrong.  You'll need the BMW branded water or warranty will be void.
To be honest, I would be surprised if they fill it just with water (distilled or otherwise).  I would expect that it should be filled with mix of water/methanol to get the gains that they claim (68hp & 36lb-ft).  The methanol helps increase the octane with the water aiding in cooling the intake air charge.  Something like Snow Performance's Boost Juice would do the trick.
Offline RaHorakhty
  • Carma: +2/-7
« Reply #23 on: October 21, 2015, 02:52:56 pm »
Mmm. I could use some of that Snow Performance Boost Juice right now. I'm feeling kinda sleepy and have a few hours left in the workday.
Offline dkaz
  • Carma: +289/-389
  • Flip flop
  • Cars: 12 Mazda 5 GT 6MT
« Reply #24 on: October 21, 2015, 03:52:32 pm »
Thats why I do not get all the stickers and badges on vehicles with the flex fuel crap....yeah, in the states, maybe, I have never heard or have seen an E85 pump in Alberta, BC, Sask or Manitoba.
There's Arcade Station in West Vancouver that sells E85. Some of my tuner buddies have started running a 30/70 mix of that with typically Shell V-Power gas and love the extra HP they get out of their engines. Downside is having to clean the fuel filter like every oil change.
http://arcadestation.ca/
Other than the added performance aspect, I'm generally against E85.
« Reply #25 on: October 21, 2015, 03:52:47 pm »
Nothing new here BMW was using methanol/water mix injection in their aircraft engines in WW2, primarily the FW190.
Offline mixmanmash
  • Carma: +103/-326
« Reply #26 on: October 21, 2015, 03:56:45 pm »
The only reason to run E85 is for added performance.  Why are your buddies running a 30/70 mix?  That's worse for phase separation than running full on E85.  And from all the research I have done, there is no need to clean the fuel filter that often.
« Reply #27 on: October 21, 2015, 03:58:37 pm »
It was very popular in aircraft, I've worked on a few water/meth pumps over the years.....the corrosion is horrid.
« Reply #28 on: October 21, 2015, 04:24:24 pm »
It was OK in German fighters because I don't think they had time for corrosion before they were shot down.
« Reply #29 on: October 21, 2015, 04:28:16 pm »
Yeah....werent made for the long run lol
Offline dkaz
  • Carma: +289/-389
  • Flip flop
« Reply #30 on: October 21, 2015, 04:34:44 pm »
From what they responded, it kills the seals and gums up the injectors, since the components aren't designed to handle E85.
  • Carma: +1254/-7214
« Reply #31 on: October 21, 2015, 05:07:42 pm »
I think they might be loony.  E85 doesn't gum up injectors.  And any seal in a car made in the last 15 years is E85 compatible.
Unless these guys are running older cars and were just too cheap to upgrade their components.
Offline dkaz
  • Carma: +289/-389
  • Flip flop
« Reply #32 on: October 21, 2015, 06:38:35 pm »
Mazdaspeed 3 and Scion FRS
Offline mixmanmash
  • Carma: +103/-326
« Reply #33 on: October 21, 2015, 06:44:34 pm »
This.
« Reply #34 on: October 21, 2015, 06:54:07 pm »
I'm perplexed.  Doesn't make sense.
« Reply #35 on: October 21, 2015, 07:04:44 pm »
Yup, BMW needs to add more stuff. More turbos more injection thingies, yup, BMW should pile it on.
« Reply #36 on: October 21, 2015, 07:07:09 pm »
Yea..you think they got problems with exploding turbos...wait till you see what happens when an injection system fails.
Offline mixmanmash
  • Carma: +103/-326
« Reply #37 on: October 21, 2015, 07:28:01 pm »
Could you imagine if it fails open....  Hydrolocked engine would be a spectacular failure.
