i've always debated those... very cool. do you take your hard top off in summer?
I do put the soft top on, tooscoops...it has two hinges on it in the rear...I opted for the quick release mechanisms on the front rather than having to carry a ratchet set to remove the front bolts in order to pivot it back to remove or drop the top. The hardtop tucks in next to the motorcycle in the garage over the summer.
Looking to get a cab cover from Rampage that I can through over the roll cage that covers the passenger area including when the doors are off. Easier to do that overnight since I have to park outdoors.
Do you carry stuff on the rack?
Hi pi - I will be, just had it installed last fall. Am looking for some serious cargo netting to tie down camping gear. On the rack is a standard 'back' panel that is overhead the rear passengers and a pop out 'front' panel that is over top the front passengers. Also came with the ladder and the wind buffeting device on the front.
The quick release and pop out panel were extra cost options.
