Cool article but it was not designed for space travel as there is no air in space It was designed as an inlet duct for aircraft.
Yep, reality sucks....or blows. You decide.
The Lotii also have them.Completely flat undertray too.
Quote from: Turbo Bob on March 13, 2015, 12:02:48 pmThe Lotii also have them.Completely flat undertray too.Is there a diffuser at the back? I wonder if those ducts are sucking in high pressure air and letting it out in a low pressure area ( the diffuser) to give a little bit of downforce...or rather NOT to provoke lift from that flat underside.
Quote from: Snowman on March 13, 2015, 07:54:52 amCool article but it was not designed for space travel as there is no air in space It was designed as an inlet duct for aircraft.Only you could get into space without going through the atmosphere Snowman.... Beam me up Snowy!
