When temperature drops, so does the air pressure. When you are in the midst of a cold snap check the air pressure in the morning before you begin to drive. You will find the tires a little lower than normal. Bump your pressure to the one listed on the driver's door placard or owner's manual. Remember to check your pressure once a month or when there is an extreme weather change.
