I see Hyundai is trying to out-Prius the Prius. Good luck with that one...leave the split window to Toyota.
Under the hood, Hyundai will bolt in a new engine exclusive to the Ioniq that boasts 40 percent thermal efficiency and generates 104 hp and 109 lb-ft of torque. It’ll work alongside an electric motor good for 43 hp and 125 lb-ft, and both power sources will be put to work through a new six-speed dual-clutch transmission
I'm wondering what the combined output will be, but 40% thermal efficiency seems high for an ICE, but low comparatively for an electric-only motor. I'm not sure what the TE is for other hybrids out there, but if Hyundai is the first to publish a combined number, it may be more marketing hype than actual engineering primacy. I'm interested to know the answer.
As for the tranny, new 6-speed DCT - why not use the 7-speed unit, especially when hybrids tend to do a bit worse at highway speeds? Most people still don't like traditional CVTs, but the way that Toyota integrated the eCVT in the Hybrid Synergy Drive is actually excellent...I absolutely love the planetary gear shift Power-Split Device.
